The tale of three P-38 Lightnings...Matchbox, Monogram and Academy.
  • Wouter
    • 742
    #91
    Can't go wrong with a P-38 for me. Looks good so far Richard!
    • Steven000
      • Aug 2018
      • 2848
      • Steven
      • Belgium
      #92
      Hi Richard, looks very nice :thumb2:
      Yes a clear coat will darken the base color, basically what's happening is that the clear coat is shinny and will reflect a part of the light illuminating your model, the reflected light bounces off and doesn't get to the base color, and because of that, this part of the light rays doesn't lighten the base. (It's a bit more complicated then that but easier to understand)
      • rtfoe
        • 9205
        • Richard
        • Shah Alam, Malaysia
        #93
        Thanks Wouter and Steven...yes the basics of science and light refraction. Amazing how light reacts to certain material and surfaces causing the effects we see and not the reaction of the paints as one would percieve. The play of light is used in modulation or forced highlights much in the same way without the use of varnishes I think. :smiling4:
        • rtfoe
          • 9205
          • Richard
          #94
          Oh dear...just realised I suddenly stopped this post and left it hanging. Ah...yes now I remember why, my sister had come up from Sydney for a visit for a whole month and I played host and toured the country scouring favorite eating spots as Asians do.:smiling2:
          So I'll continue where I left off if you guys are still interested. Will get on to my laptop tonight as all my piccies are jn there.
          • rtfoe
            • 9205
            • Richard
            #95
            Decals went on with the usual decal softener reacting to the Future varnish but usually vanishes with another coat of Future applied.
            The 87 had only a slight tinge of the smoky white on the right side of the 7.
            The petrol cap markings also had these whitish marks but you'll see in later images they're gone with the second application of Future and then matt varnish.
            I carefully painted white glue to mask the turbo boosters to apply some light grey stains that are created by the heat and exhaust.
            • rtfoe
              • 9205
              • Richard
              #96
              The matt varnish has brought back the color about halfway and the white spots have disappeared but some have appeared because I didn't wipe my sweat stains away properly so it's not a weathered effect. Some glue has crept under the canopy, nothing I can do about it but to next time be skin-flint with the amount of glue applied.
              close ups can really show up all the blemishes and dust.
ID:	1151256Click image for larger version
ID:	1151257Click image for larger version
ID:	1151258Click image for larger version
ID:	1151259Click image for larger version
              From this distance the dust and blemishes aren't noticeable.
              • scottie3158
                • 14443
                • Holbeach
                #97
                Richard,
                Even with the issues you have had it is still a cracking result.
                • rtfoe
                  • 9205
                  • Richard
                  #98
                  Thanks Scottie, actually my main peeve is my sweaty palms and I don't like wearing gloves to handle when building.
                  • rtfoe
                    • 9205
                    • Richard
                    #99
                    Hi, back again with a sudden loss of concentration and forgot I still have to finish this...
                    In short range sorties the hard point for fuel tanks was substituted for iron bombs.
                    I sanded the tyres to get the weighty look.
ID:	1155706Click image for larger version
                    The extra nose weight paid off and she sits right.
ID:	1155708Click image for larger version
                    Will be adding chipping to the upper surfaces...
                    • rtfoe
                      • 9205
                      • Richard
                      #100
                      Here are more with the chipping added...
                      Just a bit on the upper wing and leading edges. The left window is shown wound down.
ID:	1155818Click image for larger version
ID:	1155819Click image for larger version
ID:	1155820Click image for larger version
ID:	1155821Click image for larger version
ID:	1155822Click image for larger version
                      • scottie3158
                        • 14443
                        • Holbeach
                        #101
                        Richard,
                        That is a great result.
                        • Airborne01
                          • Mar 2021
                          • 4188
                          • Steve
                          • Essex
                          #102
                          Originally posted by colin m
                          They look great Richard. A trio of Lightnings, I think we need a collective noun for this.
                          A Flash of Lightnings perhaps? Individually a 'Bolt'?
                          • rtfoe
                            • 9205
                            • Richard
                            #103
                            Thanks Scottie and a flash near sounds about right.
                            • adt70hk
                              • Sep 2019
                              • 10506
                              #104
                              Richard,
                              Very nicely done indeed.
                              ATB.
                              • rtfoe
                                • 9205
                                • Richard
                                #105
                                Thanks Andrew.
