2x Bf 109 F-4 (1/48)
    Originally posted by Steven000
    the swastika should get a white outline but I'm not sure if I will be able to pull that one off :thinking:
    I would kind of expect there to be two sizes of mask for that, a larger one for the white and then a smaller for the black. Are you sure the two swastika masks are exactly the same size? (Technically, it should also have a black outline around the white, so three sizes of mask, but I doubt you could get them all lined up correctly in this scale.)
    • Steven000
      • Aug 2018
      • 2893
      • Steven
      • Belgium
      #47
      Thanks for the comments!
      Yes I don't think I'll give the white outline a try, should have started with white before masking...
      Would be a lot easier if they included the swastika's in the decals again. Could save a lot of precious time on the bench...
      I just ordered a small decal sheet for future Luftwaffe planes.
      Kind regards,
      Steven
        • 16197
        Hi Steven
        Coming along really well. The masking has worked well - very neat. That masking putty does tend to slump on vertical surfaces. Quite a problem as it means you have to work quickly - certainly can't leave it while you go for a cuppa :tongue-out3:
        I'm enjoying this :thumb2:
        • rtfoe
          • 9208
          • Richard
          • Shah Alam, Malaysia
          #49
          Hi Steven, your plane skills haven't left you after 20years. Great build...just don't know how I missed this. Just went through the pages and seen the first time use of that putty...looks like slime from Nickelodeon. Blu-tac is what I use up till now.
          Engine detailing... :thumb2: Dashboard dials...:thumb2: Decal masking...:thumb2:
            You can buy decal sheets with nothing but in different sizes.
            • colin m
              • 9040
              • Colin
              • Stafford, UK
              #51
              Brilliant work Steven. Stretched spruce is something I just have no luck with. I end up producing yards of the stuff for just an inch or two of usable sprue.
              • Steven000
                • Aug 2018
                • 2893
                • Steven
                • Belgium
                #52
                Originally posted by colin m
                Stretched spruce is something I just have no luck with. I end up producing yards of the stuff for just an inch or two of usable spruce.
                Yes it's something you need to try a few times indeed : D, you need to heat it, but not overheat it, it should be just warm enough to pull it hard about 20-30cm. I find it doesn't work with 'soft' sprues like ICM, and you should try to heat the sprue about 1cm in length, so not exactly at 1 point if that makes sence...
                Hope you'll be able to produce some thin wires :thumb2:
                Cheers, Steven
                  Brilliant work Steven. Stretched spruce is something I just have no luck with. I end up producing yards of the stuff for just an inch or two of usable spruce.
                  I've had much better luck with hot glue. A blob on a coffee stirrer etc, touch it with another and stretch away.
                  Seems much more controllable but obviously no good if you don't have a gun.
                  • Lee Drennen
                    • 7738
                    #54
                    Steven. That’s looking sweet great job on the masking at one point it looked like it was in a cocoon lol
                    • colin m
                      • 9040
                      • Colin
                      • Stafford, UK
                      #55
                      That might be my problem. I use a heat gun which applies a lot of heat over a bigger area.
                      A glue gun Andy ?
                      • Steven000
                        • Aug 2018
                        • 2893
                        • Steven
                        • Belgium
                        #56
                        Yes in the older (armour)kits they always showed a candle for making the antenna, the candle-trick still works for me so I keep using it. I heat about 1cm in the middle of the sprue, (I turn it around like a chicken) then the plastic turns shinny/melted and then I turn it away from the flame, and give it a good pull...
                          I use a cigarette lighter to stretch sprue — mainly so I don’t have to keep a lit candle around all the time I’m working with the material. The trick, IMHO, is mainly to try different kinds of sprue and different lengths of time heating it.
                            A glue gun Andy ?
                            Yes. I'm lucky to have one from previous hobbies but I'm sure not everyone does.
                            • Mini Me
                              • Jun 2018
                              • 10711
                              #59
                              very handy tool...everyone should have one.
                              • flyjoe180
                                • Jan 2012
                                • 12958
                                • Joe
                                • Earth
                                #60
                                Fantastic stenciling Steven
