Amodel I-207
  • stillp
    • 8296
    • Pete
    • Rugby
    Amodel I-207
    The Blenheim is nearly finished, and the next GB hasn't started yet, so I looked around for a quick build... and found this
    Picked up for £4 at a show last year. Why choose this one? Well, it's small, with only 41 parts and a simple scheme, so it shouldn't take long (famous last words). It's just under 80 mm long with a wingspan of 96 mm, and yes, it is 1/72. Anyway, I haven't built a biplane for over half a century, and this one has no rigging.
    Here's the sprues:
    There are two clear sprues, both with the same flash, with only one part eachClick image for larger version
    They seem to have used old engine oil as a mould release agent though
    And there's a bit of metal stuck in one of the fuselage halves
    But it has some nicely moulded detail
ID:	1118890Click image for larger version
    The brown staining didn't wash off with water and detergent, or with IPA.
    Better get on with it then.
  • yak face
    • Jun 2009
    • 14242
    • Tony
    Obscure iron curtain subject , limited run kit , poor moulding , cheap - welcome to my world pete !! Ive built a few Amodel kits and its certainly a challenging build , every single piece needs cleaning up / fettling but with a bit of patience and a lot of sanding sticks and filler the end result can be a nice model of a rarely seen subject .
      It definitely looks a challenge, but I’m sure you’ll transform it in to something to be proud of.
      Will be keeping an eye on this.
        • 16196
        Hi Peter
        Certainly not seen this before. Looks as if you have your work cut out but as Tony says ".... with a bit of patience and a lot of sanding sticks and filler the end result can be a nice model of a rarely seen subject ."
        • stillp
          • 8296
          • Pete
          • Rugby
          Thanks chaps. Did I say this was going to be quick? :disappointed2:
          • Mini Me
            • Jun 2018
            • 10711
            Pete, does the bomb come with landing gear also?:smiling2: that baby is huge! It appears the manufacturer saw fit to include some flak damage as well. Lol. I hope this one goes well for you,
            an interesting subject, for sure. Rick H.
              Good of them to supply all of that extra plastic around the parts. No doubt you'll need it later to fill the inevitable gaps.
              • stillp
                • 8296
                • Pete
                • Rugby
                2 x 250 kg bombs Rick!
                • Mini Me
                  • Jun 2018
                  • 10711
                  It's a wonder that bird could get off the ground! Rick H.
                  • stillp
                    • 8296
                    • Pete
                    • Rugby
                    Pretty good performance, according to Wikipedia:
                    • Maximum speed: 436 km/h (271 mph)
                    • Range: 700 km (435 miles)
                    • Service ceiling: 9,150 m (30,020 ft)
                    • Rate of climb: 13.44 m/s (2,,646 ft/min)
                    Anyway, here's the results of a day's work:
                    Thanks for watching!
                    • stillp
                      • 8296
                      • Pete
                      • Rugby
                      A bit more done:
ID:	1119062Click image for larger version
                      Lots of filling to do. While the filler is drying I can start trying to make the lower wing fit the fuselage. There's a large tapered gap each side, and one wingtip sits higher than the other! Oh, the fun!
                      • Mini Me
                        • Jun 2018
                        • 10711
                        Still and all, it is starting to take shape....the joys of modeling! Rick H.
                        • stillp
                          • 8296
                          • Pete
                          • Rugby
                          Here for your amusement are the wing gaps:
ID:	1119086Click image for larger version
                          Difficult to see in the photos, but the gaps are both fairly narrow at the back, but at the front, one is about 2 mm wide, the other a bit less. The wing is just blu-tacked at the moment.
                          The instructions suggest fitting the undercarriage next, but it looks a bit fragile, and given the amount of filling and sanding those wing gaps will need, I think I'll fit the lower wing and maybe the tail next.
                          Thanks for watching,
                          • Mini Me
                            • Jun 2018
                            • 10711
                            Time to break out the 1" putty.
                            • yak face
                              • Jun 2009
                              • 14242
                              • Tony
                              You could try cutting a piece of sprue about 2 mm wider than the gap between the fuselage halves at the front Pete , if you wedge it in without glue and see if it spreads the front enough to minimise the gap with a dry fit , if not then you can always go back to plan A and fill it
