MiG21-MF Eduards Weekend kit.
  • KarlW
    • Jul 2020
    • 1522
    #16
    Not much bench time last night, a local suicide has left the whole community in a bit of shock, I did however spray my interior with Vallejo's cockpit emerald green "faded". Though I'm now wondering how to get it closer to the pre-painted PE in colour. Thinking of using a blue green filter.
      Karl,
      I'd use a matt varnish, just tinted with a hint of neutral grey - obviously, starting off very lightly & increasing to suit the panel.
      You said that you used Frisk film, because it was cheaper than Tamiya Masking sheet - I'm always looking for cheaper ways to do things - is the Frisk film much cheaper? I've had a quick internet search, and I can't find a massive price difference!
      • KarlW
        • Jul 2020
        • 1522
        #18
        I can get 10" by 4 Yard rolls of frisk for about twice the price of a pack of 5 (10" by 7") Tamiya sheets which is about 10" by 1 yard.
        • Lee Drennen
          • 7738
          #19
          Originally posted by KarlW
          So despite stuff for this arriving earlier I decided tonight to continue doing a scenic base that I started a few weeks ago.
          I wanted a rough utilitarian, “it’s not broken, it’s not getting fixed” feel to a taxiway or some part of an airfield. Slabs are 1/48 scale 5m by 3.5m, individually cut from xps foam, edges roughed and each sanded before being glued to an MDF base. The ground, which was tonights addition, is a craft shop ‘Art Mache’ with a touch of pigment added.
          [ATTACH=CONFIG]n1128662[/ATTACH]
          Are you going to attend those water spots or leave them as some sort of stain ? Not very convincing at the moment
          • KarlW
            • Jul 2020
            • 1522
            #20
            What water spots? There's no paint on that and the mache is still drying as it's only just applied in that picture..........
            • Lee Drennen
              • 7738
              #21
              Here Click image for larger version
              • KarlW
                • Jul 2020
                • 1522
                #22
                That's just light on the surface, might be a bit shiney from roughing it with a stone but definitely dry. It's all going to get painted over anyways.
                • KarlW
                  • Jul 2020
                  • 1522
                  #23
                  One of those nights where I don't seem to have gotten much done.......
                  Cleaned up and primed some parts.
                  And sprayed the intake and exhaust interiors and started to add the interior etch detail. Think I need the optivisor to add the rest.
                  Can't decide if these etch kits being self adhesive is a help or a hindrance, difficult to bend stuff that wants to stick so you have to cut the backing paper.
                  • KarlW
                    • Jul 2020
                    • 1522
                    #24
                    Been a while since I've got to the bench, I'll blame binge watching Shameless....
                    Wasn't happy with the colour mismatch between the paint and the pre-painted etch so an trying a blue/green oil as a filter/wash, definitely going the right direction.
                    Getting close to the point I can zip up the fuselage.
                    • dave
                      • Nov 2012
                      • 1844
                      • Brussels
                      #25
                      I mixed my own using the Mr Hobby Aqueous, H46 and H25 in a 1:1 ratio as per the painting guide in the instructions i had and it came out pretty near an exact match to the Eduard photoetch
                      • KarlW
                        • Jul 2020
                        • 1522
                        #26
                        Apparantly they changed the colour at some point, the call out in this doesn't call for mixing paints so I just worked with what I have. More fun.
                        (Though I have bought the Mission Models paint which I have read is an exact match for when I get to a MiG-23)
