Esci 1/72 Sea Harrier
  • stillp
    • 8296
    • Pete
    • Rugby
    I think this is going to be my next build:
    As per my usual, picked up for a fiver in a charity shop. Box a little squashed, but the sprues look undamaged in their sealed bag. Not sure if the decals should be this shade of yellow though:
    I've never seen this before - two of the sprues joined together and folded one over the other.
    Had me worried that some of the parts were interlocked, but no, it unfolded without damage.
    Three grey sprues plus one clear:
    This is my first Esci kit, and so far I'm impressed - very little flash, not ejector marks in visible places as far as I can tell, and nice finely-recessed detail:
    There are some flow lines on the larger surfaces, as you can see on the wing above, and a couple of nasty sink marks on the forward fuselage halves, but nothing major. The canopy has some stress marks and a few scratches, but I'm sure it'll look better after a bath in Klear/Pledge/JohnsonsMultisurfacePolish.
    Any comments or suggestions will be gratefully received.
    Should get started tomorrow.
    I'll sit in if you don't mind!
    • stillp
      • 8296
      • Pete
      • Rugby
      You're very welcome Chris! Let me know if when I start doing something stupid please.
        I'm here for the tips and tricks!
          Esci was one of the premier manufacturers, back in the 1970s and 80s or so, and this is an original kit so it won’t suffer from having worn-out moulds as much as current reissues by Italeri (or whoever) might. They’re also the one who popularised 1:72 scale for armour models, BTW, apparently largely because they weren’t really aware of the British 1:76 tradition and were already making aircraft in 1:72
            I'll follow along Pete, not I can offer any advice , unless you want to set fire to it !
            • Mini Me
              • Jun 2018
              • 10711
              I'm in and I brought Matron along in case 453 starts playing with matches Rick H.
              • minitnkr
                • 7785
                • Dayton, OH USA
                Back to large scale I see:smiling:. PaulE
                  • 22954
                  Looks a nice kit Peter, just pulled up my chair. I've got my cup is the kettle on?
                  • PaulTRose
                    • Jun 2013
                    • 7113
                    • Tattooine
                    always happy to see a harrier built
                    i always found the styrene that esci used to be quite brittle, easy to clip/cut off a bit more than planned
                    Per Ardua
                    • colin m
                      • 9038
                      • Colin
                      • Stafford, UK
                      Esci are nice little kits. And a Shar as well, ticks all the boxes for me. I built the Italeri GR3 (was an Esci in another life) a few years back, apart from a bit of a sparse cockpit, it was a nice build. I look forward to seeing this one built.
                      • stillp
                        • 8296
                        • Pete
                        • Rugby
                        Done a little more. The plastic isn't brittle Paul, but it doesn't sand very well. I should have looked more carefully before I wrote that there weren't any ejector marks, I've found quite a few now.
                        I don't know if this risks being a tail sitter so I stuck some weight in the nose just in case.
                        The nose halves above have a bit of a warp, so they fit together at the front or at the rear, but not both, so it'll need a spot of filler.
                          • 16193
                          Hi Peter
                          I always imagined that Esci kits were poor but this looks rather nice. Interesting what Jakko said about Esci kits. I am looking forward to see how this goes.
                            Looking good! Noseweight is prudent, just in case.
                            • stillp
                              • 8296
                              • Pete
                              • Rugby
                              Here's a shot of the cockpit closed up:
                              Next task is to join the main fuselage halves, which will need a bit of a juggling act as there are several parts that need to be fitted between the halves.
