Hasegawa 1/72 Lockheed F-117A Nighthawk
  • Steven000
    • Aug 2018
    • 2893
    • Steven
    • Belgium
    #16
    Nice work Joe! Looks all great :thumb2:
    Steven
    • adt70hk
      • Sep 2019
      • 10542
      #17
      Looking very good Joe.
      ATB.
      • colin m
        • 9037
        • Colin
        • Stafford, UK
        #18
        Good looking build Joe. Is it any wonder people around area 51 thought they were seeing UFO's
        • flyjoe180
          • Jan 2012
          • 12956
          • Joe
          • Earth
          #19
          Originally posted by papa 695
          Nice steady work so far Joe
          Cheers Ian
          Steven
          Cheers Steven
          ATB.
          Thanks Andrew
          Thanks Colin. Yes, a very weird aircraft!
          • flyjoe180
            • Jan 2012
            • 12956
            • Joe
            • Earth
            #20
            Next I moved in to the underside fuselage and tail fin seams. Sanding the filler takes some care as there are angles all over the place that need to be retained and not smoothed over.
            Reference photos show there are no seams on the wings whatsoever, so I dealt with all of those. I attached the wings as best I could to the fuselage. There's a positioning lug for each wing, but the starboard one was out of alignment so I cut the lug down in size and held the wing in place for a better fit. You can see the small gaps at the wing roots.
            It's now smooth and the gaps filled. I also filled the lines that join the wing at the leading edges. I've also added an anti-collision light to the port underside, created from the clear sprue tree. The airframe will next be given a wipe down with IPA.
            The nose landing gear leg was then assembled. The landing light face was lightly sanded, polished up, and then masked using Humbrol Maskol. The rear section of the light was given a coat of chrome paint. After painting I hope the lens looks okay. It looks messy in this very close up picture.
            The landing gear components have been cleaned up on the sprue, and all parts are now ready for priming. Stay tuned.
            • flyjoe180
              • Jan 2012
              • 12956
              • Joe
              • Earth
              #21
              We now have a grey ghost Click image for larger version
              Now the fun can begin
                • 19106
                Looking great Joe. In the grey it looks really futuristic doesn’t it.
                • Vaughan
                  • Apr 2011
                  • 3221
                  #23
                  As Tim says futuristic it wouldn't look out of place in Star Trek. Looking forward to the paint going down.
                  • flyjoe180
                    • Jan 2012
                    • 12956
                    • Joe
                    • Earth
                    #24
                    I've progressed a little bit with this build. The landing gear components and door insides are all painted white. The landing gear bays were painted white and masked off.
                    The airframe was painted Matt black. I managed to get some variation in the black by layering the paint lightly and building it up gradually, leaving it darker on the underside and on the sides. This won't be too worn, just enough fading to create some visual interest in what is otherwise a pretty boring scheme. It will darken under a the varnish coats.
                    I was going to mask off some of the panels and paint them a dark grey, but I have discovered that Matt black likes to absorb dust and particles that appear out of nowhere. So this ugly sucker is off to the booth for a gloss varnish to help protect that black aint finish. Then I will apply the dark grey, gloss it again, and apply the decals.
                    • Steven000
                      • Aug 2018
                      • 2893
                      • Steven
                      • Belgium
                      #25
                      Nice progress Joe, good idea to layer the black for a bit of tone variation.
                      Hope you can get it dustfree again before adding the gloss, I'm always fighting dust too!
                      Steven
                      • flyjoe180
                        • Jan 2012
                        • 12956
                        • Joe
                        • Earth
                        #26
                        Time slipped, and i got slack and lacked motivation, but the F-117 is crawling towards the finish line.
                        Once the black paint was protected with a varnish coat, I maske doff various panels according to photo references and painted them dark grey .
ID:	1155668Click image for larger version
                        Decals on, and a panel line wash using a light grey.
                        Everything was smoothed down, I then applied two light matt varnish coats. Once dry I masked off the tail areas and painted the exhaust areas, which are a base of steel with a light burnt iron effect which follows the exhaust fins out from the fuselage.
                        Next steps are to fit the landing gear, gear doors, unmask the clear parts, and paint my home made anti collision light on the lower surface. Nearly there!
                        • flyjoe180
                          • Jan 2012
                          • 12956
                          • Joe
                          • Earth
                          #27
                          Wheels and landing gear doors are on. Had to bore out the holes for the main legs but otherwise it went in no problems. A few details to do and a bit of tidying up, and should be complete by end of play today.
                          I had one issue when I unmasked the clear parts. The nose sensor on the upper surface, I just couldn't get the masking tape off it. And then it occurred to me I was scraping paint and under that was plastic. I had fixed the lens into the nose with the masking tape inside. Gentle paint removal followed by high grade sandpaper, and lastly Tamiya Polishing Compounds to the rescue. Managed to salvage the part and get it fixed into place. I need to remove some residue from the polishing compounds.
                          The very few issues I've had with this kit have been of my own doing.
                          Completed photos to come in the near future.
                            • 22954
                            #28
                            Great work Joe.
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #29
                              YES Joe ive really enjoyed this build very well done m8
                              chris
                              • adt70hk
                                • Sep 2019
                                • 10542
                                #30
                                Joe
                                Very hard indeed to get a monochrome paint job like this look interesting but you've achieved it.
                                Very well done indeed.
