HobbyBoss 1/48 F6F-5 Hellcat - finishing a part built shelf queen!
    I realise, looking at the pictures, I haven't got the Sea Blue deep enough - it should be just below the engine prop shaft. I'll have to fire up the compressor tomorrow, and fix that.................
      I think the exact lines varied a lot on the real plane, so unless you think it looks wrong, I’d say you can just leave it as it is.
        Jakko,
        yes, I've seen pictures , where the Sea Blue connected up with the wing surfaces. I'll wait until tomorrow & see what it looks like in daylight, before carrying on
        • yak face
          • Jun 2009
          • 14237
          • Tony
          #19
          How are you thinning the hataka paints dave ? I just wondered as ive been using them a fair bit recently and found them very nice . I thin them with vallejo thinners if they need it , most times the red line will spray straight out of the bottle . I have noticed though if thinned they will need at least two thin coats as they can be a bit transparent sometimes , although ive been spraying the blue line ( supposedly optimised for brushing) thinned slightly and they seem to have good colour density .
            • 16192
            Hi Dave
            Well whatever the history of this you seem to have it almost done and it's looking good.
              Tony,
              I'm using straight tapwater - they don't need a lot of thinning, but they seem a lot more sensitive to use than say, AK or MiG. One silly thing I notice is that it's too easy to overtighten the cap on the bottle & damage the thread!
                I modified the Sea Blue upper surfaces, then gave an all over spray of gloss varnish. Then Decal time!
                Still a fair few stencils to add - I lost two decals when they shrivelled up when they came off the backing - the others are OK, so it may be the printing that was in error - they aren't obvious by their being missing!
                  More progress - in fact the next pictures will be in the 'completed' section
                    Thanks for following the build, results are here https://www.scale-models.co.uk/threa...mpleted.37389/
