revell 1/48 .. mosquito mark iv .. some help pls
  • saguy
    • Feb 2011
    • 570
    hallo .. doing this at present .. need some advice .. the canopy is a bit ill fitting .. fine on one side and not on the other or the front . any suggestions on the best way to correct this .. all i can think of is putty but maybe there is another way ...?
    thks
    lindsey
ID:	1160073Click image for larger version
ID:	1160074Click image for larger version
ID:	1160075Click image for larger version
  • Mark1
    • Apr 2021
    • 4156
    I personally would probably sand the edge of the fuselage around the cockpit to suit the canopy if possible.
      • 16029
      Hi Lindsey
      It might be possible to cut a sliver of thin styrene and glue it along the edge of either the canopy or the body to fill the gap. I think I would try to glue a strip along the canopy edge and then dry fit and sand to get a good fit.
      Bear in mind that I'm not a wingy thing builder so I may be talking rubbish :tongue-out3:
      • AlanG
        • 6296
        Or you could contact Revell with a picture of said canopy and they might send you out a replacement t see if that fits any better
        I've had a few replacement parts from them that i've ether broke, lost or didn't fit.
        • flyjoe180
          • Jan 2012
          • 12664
          • Joe
          • Earth
          Hi Lindsey. You could use PVA or similar white glue. Run it around the edges, allow it to settle for a bit, then use a damp cotton bud to smooth the edges. You may require a few passes with the glue and bud. It will dry clear and will require touching up with paint, but probably the least drastic if you can't get a replacement canopy from Revell or you need a result now. You could also use Humbrol Clearfix or a similar adhesive that does not react with the clear plastic. Good luck!
          • saguy
            • Feb 2011
            • 570
            Thks gents ... I am leaning towards the styrene or glue options .. Will give it go and see where i end up ... :thumb2:
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              Originally posted by Jim R
              Hi Lindsey
              HI Lindsey well ive built a few wingy things in my past an i think Jim's idea is a good un an he 's not talking rubbish but thats how i would also do it to fill the gap as you can get very thin strips of evergreen to do the job
              an good luck also from me
              ATB chris
              • rtfoe
                • 9204
                • Richard
                • Shah Alam, Malaysia
                Hi Lindsey, had I seen this post earlier I would suggest you change the canopy to the later version that fits the bomber version with the clear nose.
                The image on the box top shows the earlier hard nosed version with the canopy that you have but the kit you've built is the bomber version. Revell must have given you the wrong canopy.
                • colin m
                  • 8927
                  • Colin
                  • Stafford, UK
                  I agree with Richard, that canopy looks like the wrong one.
