Thank you Andrzej. Here are the results:
The gloss coat is not completely satisfactory, but I like it so I'll go on. The props and the landing gear doors have been coated with another product, a spray wax for wood (the closest thing I could find similar to Klear here in Italy) and I'm not displeased about the final effect, even if it is not easy to spray a thin and uniform coat (the still wet and uneven coat is clearly visible on the landing gears doors, but when it dries it's not as bad as one could suppose).
Decalling is still ongoing: today I managed to apply the stars and those on the prop blades. The decals are a bit on the thick side, but better thick than fragile.
Probably tomorrow there will be a second, and hopefully final, decalling round with plenty of small, red decals, mainly on the wings and a large nose art.
Thank you for your patience and support.
Andrea
Andrea
