Andrew's 2x AZ Model Bf 109 G-6 - JG300 'Wilde Sau' (The Hunters and the Hunted)
  • The Smythe Meister
    • Jan 2019
    • 6248
    #166
    Just had a good ol' catch up with this Andrew,and gotta say .....
    ...... WOW!! ....
    Excellent looking paint schemes on BOTH planes
    SUPERB work mate... I love it!!
      • 19032
      These are looking better and better. Nice job.
      I’ve found the best way to determine the shape of the exhaust staining is by looking at winter camoflage examples, by the way. The white finish shows the shape and extent of staining very well. Unfortunately black and white shots don’t show the colour though :disappointed2:
      • adt70hk
        • Sep 2019
        • 10506
        #168
        Originally posted by Mark1
        Looking good,getting close to the finish line .
        ...... WOW!! ....
        Excellent looking paint schemes on BOTH planes :smiling3:
        Thanks chaps!!! Glad you're liking it. I'm pretty pleased with his they're going and despite a few problems I've generally enjoyed the process.
        Tim, good point on the exhaust front. Will have a closer look next time on white/lighter paint jobs.
        Thanks again chaps.
        ATB.
        • Mickc1440
          • 4826
          #169
          What a lovely pair Andrew. Great job
          • adt70hk
            • Sep 2019
            • 10506
            #170
            Thanks Mick. Not a patch on your Mossie but pleased nonetheless.
            ATB.
            • adt70hk
              • Sep 2019
              • 10506
              #171
              Modellus Biblicus
              The Book of Wingy Things Ch 12 vs 27-29
              And after many days and nights of toil, the Modelling Gods spoke forth and legs did emerge from underneath the roots of the wings of the birds of Messerschmitt. And there was much wonderment amongst the nations as the legs had not feet but behold.....discs with rims of rubber!!! And then there was much rejoicing in the world as all that beheld the wonders before them realised that the end doeth approach!!!!
              Here endeth the lesson.
              Ok, so now I've got that out of my system the undercarriages are indeed on, as are the drop tanks. So all I've got to do now is at the pitot tubes and antennas, and then then give it a final clear coat followed by the antenna 'wires'.
              Getting the angles right for the wheels, undercarriage struts and covers was not helped by some fit issues and poor instructions - the blue ones in particular are not fitted well/correctly so I think one wing looks a bit high but at least I worked out with Yellow 4.......but personally I'm blaming Willy Messerschmitt for not considering modellers when designing this plane and not keeping everything as nice to follow right angles!!! :smiling5:
              ACW as usual.
              ATB
              • InFlames
                • Feb 2012
                • 466
                #172
                Great progress! These night fighters were so cool using so many different non standard camos. And hats of on perseverance - I started a couple of AZ kits but after some really big fit issues just put them back into boxes.
                • adt70hk
                  • Sep 2019
                  • 10506
                  #173
                  Thanks Seb. Glad you like them.
                  As I said earlier in the thread, the fit wasn't bad, it just wasn't great.
                  ATB.
                  • adt70hk
                    • Sep 2019
                    • 10506
                    #174
                    Hi all
                    So I'm calling this done.....the canopy masks came off and the radio antenna cables added.
                    The Montex masks came off beautifully. The kit supplied masks, not quite so smoothly, so I had to do some touching up. The kit supplied ones were definitely inferior and noticeably thicker.
                    However what I did discover is that vinyl masks, at least on these builds don't like going around tight angles i.e. at the rear corners.
                    I think it's because at this scale the angles are too tight for the inherent 'springiness' of the material. You then combine that with actually very little canopy for the glue to adhere to and this resulted in them lifting. Fortunately a wet cocktail stick was sufficient to scrape the overspray off.
                    The 'cable' is clear fishing line painted black. The tension on the blue one could be better but it will do.
                    Thanks to all who have joined me on the ride and your support, it's what makes this such a great forum.
                    More pics will appear in the completed section soon.
                    ATB.
                    • scottie3158
                      • 14443
                      • Holbeach
                      #175
                      Andrew they are corkers.
                      • AlanG
                        • 6296
                        #176
                        Excellent work Andrew
                        • adt70hk
                          • Sep 2019
                          • 10506
                          #177
                          Thanks guys! Glad you like them!
                          ATB
                            • Jan 2019
                            • 6248
                            #178
                            Originally posted by adt70hk
                            Hi all
                            ATB.
                            WOW and WOW again !!
                            They look excellent Andrew, very well done indeed
                            Been a thoroughly enjoyable thread from start to finish mate,love it!!
                            Andy
                              • 19032
                              Cracking stuff Andrew. Well worth all the hard work.
                              • Mickc1440
                                • 4826
                                #180
                                Fantastic finish Andrew
