Coming on nicely Geoff. The cockpit looks good. The oil wash has brought out the details.
Geoff’s - Revell 1/72 Lancaster B.III “Dambusters” tribute build
Yup, something about the Shackie birds colour scheme I liked, (the maritime version).
I'll be sticking that on my wish list when the kids scratch their noggins wondering what Mr Grumpy wants for B/Days and Christmas's!!
(But after the Bronco OV10)Comment
Following along with this one too ! I remember building one when I was a kid, still fancy a go at another! Have fun !!Comment
Hi Geoff,Hello Chaps,
Despite the lack of updates I have been busy beavering on with the build.
So here’s a quick update of progress so far.
The cockpit isn’t overly detailed and I decided to keep it simple due to wanting to finish the build by the time of the anniversary of the raid.
Following the priming it went together fairly easily.
The front section of the cockpit and gun turret interiors were given a coat of Vallejo Model Air 71.056 Panzer Dark Grey instead of the recommended black as it seems more in scale. The rear of the cockpit and interior was painted with Vallejo Model Air 71.305 interior grey/green
The various decals were then added while the pilots seat harness was picked out by brush.
Once these had settled the cockpit/interior was given a simple oil wash to tone it down a bit.
[ATTACH=CONFIG]n1199139[/ATTACH]
[ATTACH=CONFIG]n1199140[/ATTACH]
[ATTACH=CONFIG]n1199141[/ATTACH]
The wings have also been built up and the engine nacelles were added once the undercarriage bays were constructed.
[ATTACH=CONFIG]n1199142[/ATTACH]
[ATTACH=CONFIG]n1199143[/ATTACH]
Most of the ancillary parts have been put together including the Upkeep mine.
[ATTACH=CONFIG]n1199144[/ATTACH]
So a bit more construction to go but I think I’m on track to finish in time :smiling4:
Another update soon, thanks for looking :thumb2:
Geoff.
Any obvious issues so far? Just thinking ahead to mine.
ATB.
AndrewComment
Evening Geoff,
I'm still with you on your lanc. I just fell behind a bit. Driver's seat looks good and does the whole build so far, Sir!!! Seems you're making better progress than I am too...
AllenLife's to short to be a sheep...Comment
Thank you Andy, glad you are enjoying it :smiling4:
Cheers Peter :thumb2: I think it may be possible to paint the wings separately due to the wing spar system.
Thanks Jim, it it just looked too bright
before the wash.
I agree, a Shackleton is on my future build list too :smiling3:
Cheers Steve, go on, build one you know you want to :tears-of-joy:
Not so far Andrew, a bit of flash here and there but the fit has been generally good.
The clear parts aren’t good though, the plastic seems a bit grainy and mine had quite a lot of scratches in places. I’ve had to dip them all in clear which has helped :disappointed:
Thank you Allen :smiling4:
Geoff.Comment
Thanks Geoff. Duly warned!Thank you Andy, glad you are enjoying it :smiling4:
before the wash.
Geoff.Comment
I bet that would be an impressive build Chris.
To be honest I struggle with bigger scale builds, single engine aircraft aren’t too bad but anything larger just feels awkward when I’m building it.
I think I’m just weird :upside:
Geoff.Comment
Totally know where you're coming from, storage space in my 'hobby room' is becoming a little tight, and I'm not sure I've got the spare space to store a fully built 1/48 Lanc, so I'll probably end up sticking the photoetch set on e-bay and selling it on...Comment
Or you could build one and mount it on a wall
Geoff.Comment
Hello chaps,
Starting to take shape now :smiling:
Wings are not glued on yet, just pushed onto the wing spars. This should ensure that they can be painted separately which should make it easier.
The horizontal stabilisers (tail planes) have been glued into position along with a couple of inserts to blank out the upper gun turret position and a similar one in the lower fuselage.
Unfortunately I’ve met the first real problem with the build.
There is an insert which fits into the bomb bay to allow the upkeep mine to be held in place but it just doesn’t fit properly.
Both the front and rear of the insert has a pronounced step. It fits correctly everywhere else so I’m not sure why th step is there :thinking:
Looking at pictures of the real aircraft there isn’t a step, everything is flat sh so it looks like some sanding and scribing lies ahead :sad:
Geoff.Comment
That's a pain. For the rear I'd probably fill the inside with sprue glue, and when dry, just sand away. The front, I'd cut the insert somewhere away from a panel line and fill with sprue/plastic, then you can sand again, until dawn or you fall asleep.Comment
