Zoukei Mura J2M2 Rai Den, 1/32 scale.
The airframe is ready for painting. I just need to do some masking.
I had some issues attaching the engine panels, not due to poor fit, the fit was perfect. The problem is that something was not lined up perfectly which then had a knock on effect. This is a key point about how these kits are engineered and why they take so much trouble to show, in the instructions, exactly how parts should fit. A moments inattention to the instructions and it can cost you. Anyway, I got there in the end with the use of filler and sanding. I never did work out exactly where I went wrong. If I wanted panels open though, it would have been a much bigger problem.
I have all the other subs ready as well, all in need of paint before assembly.
Exactly that. It helps ensure a smooth surface. You don’t want to sand paint away, just smooth the finish hence a polishing sponge.Comment
Must admit Barry, I’ve only ever done that under a gloss or metal finish. Probably why your finishes look so much better than mine LOL….this one is no exception, by the way. Looking very nice.Comment
I have been getting on with the painting. Still got some more detail painting to do before applying decals. Here is where I am at.
Almost every build of the Raiden I have seen has been with the lightning bolts on the side. I have decided to be different and do a different aircraft without them. A much plainer, simpler scheme and the beauty is in its simplicity.
The scheme I am doing is below.
Detail painting done, note that I painted the red no walk lines. I always do this as it’s far easier and effecting than the decals.
That said Zoukei Mura decals are excellent so I decided to use them instead of painting the main markings.
First of all I applied a gloss coat. Because I spray with MRP’s lacquer varnish you do need to be a little careful not to reactivate the base paint so I use several very light mist coats and no heavy varnish coats.
I will do decals later today and, when they are bedded down, do another light gloss varnish to seal them ready for a wash.Comment
