Edward FW190A8 1\48
    Thanks Guys.
    Have made the wire i found in me tackle box painted it yellow bent it and stuck it in ,Not that easy...
    Massive hands tiny wire.
    Gonna put some oily gunk in the wheel wells
    And some canon residue in the wing and nose placements,and gotta wire up the nose guns.
    Thanks for looking and all advice gladly received and used.
    Martin
      Better pics
      Will get the big guns out tomorow cos i even put the little brass wire retainers on.
      Cheers again
      Martin
      PS; don't suppose you know what the two circular things are behind the top guns?
        mighty fine work you are doing ace
        mobear
          Thanks Mobear
          Today gonna fill a few gaps then prime it do the black line thing then put a thin coat of alclad2 ,That stuff is amazing but a bugger to clean out of me airbrush couldn't afford the alclad ab cleaner but tamiya thinner's do it ok.
          With what i've learn't from you guys the bf110 will have cables and wires added as i build cos it's fiddley as hell to fit them after everyting is glued and sealed,It'll make things alot easier,so thanks to every one.
          Martin
          ps;any one got the blue prints for the wire loom of a BF110
          • Vaughan
            • Apr 2011
            • 3229
            #20
            There's some great detail going on there Martin.
            Vaughan
              great work so far... what else to say
              I'm following and enjoying
              Roman
              • stona
                • Jul 2008
                • 9889
                #22
                Excellent stuff! Now you mustn't forget your brake lines.
                Flexible hose at the top into an anodised aluminium brake line running down the front of the strut.
                Into another flexible hose.
                The aluminium brake line was a brown colour,not black.
                The flexible hoses were this colour.
                Or black.
                The cable connected to the rotating drive,disappearing up through the top of the wheel well was part of the tail wheel retraction system.
                  you are gonna be demented fitting it all lol,class job so far though
                  mobear
                    Thanks guys, Steve photos are excellent more fiddley bits,I'll increase my Diazapan and Morphine.
                    Have put the Primer on last night ,Photoes to follow, that vallejo primer goes on lovely.
                    Thanks again for all your help
                    Martin
                      AAAAAAAAARRRRRRRRRGGGGGGGGGGGGGGGG!!!!!!!!!!!!!!!! !!f*********b******c*********m******f******A****** s*******G**F**B*****C****...........:soapbox::rant ing2::sobbing:ain::lala::death::AR15firing::bigmistake::asshole: :zoo_taz::whatever::smile3:
                      Done everything i've learnt off you guys everything was coming along nicely just finished adding wireing and hydrolic lines cos i asked for help and you guys helped know end, So i'd primed it last night looked really nice then today i filled in all the lines like you guys didn't look to bad but my hands shake real bad any way didn't take any pics left it to dry, then got the Alcad2 Alluminium loaded the airbrush and started sprayingtop if the plane went on lovely turned it over sprayed away missus called me for me pills and a cup o tea went back to model room to be greeted by alcad crazy paving on most of the underside of me FW190. Cos it had cured tryed to wipe it off to no avail. any sugestions would be greatly appreciated,As i'm Gutted.
                      was too pi**ed of to take pictures of the crazy payving.
                      Rant over,Trying to hard
                      Martin
                      Patients is a virtue am not a virteous
                        Hey Martin,
                        Yes... alu paints can be very very tricky... but... this is alu layer just for afterwards chipping effect or main color of Fw?
                        Let solve that in start...
                        Roman
                          Hi Roman how yo doin?
                          yes alli paint is for worn and chipped parts of plane the top of plane and both sides of wings.
                          The main crazy paving is underneath at the rear, so should be easy to cover up with some primer.
                          Have been carefully rubbing the affected parts with tamiya thinners and cotton buds and that has flattened it out, so am gonna try that this morning.
                          Heres hopeing
                          Martin
                            still awekening, coffe in front of me and waiting to glued canopy on seatta dry
                            try with some sanding paper, very nice sanding paper... eg. #2000 grid
                            ROman
                              Cheers Roman can always count on you for good advice, will post pics later to show progress.
                              Of to the model room now.
                              Martin
                                Martin,hope you get it sorted . I'm with Roman a light wet sanding w/2000 should do it.
