Ok, I'm new to this forum, but I want to get something started because I'm liking the atmosphere here. I actually started this kit over a year ago but it got bogged down after I started rescribing the fuselage.
Well after a year of working another kit which didn't turn out (for now), I decided I needed some therapy so I picked this one up and have been making progress. I need to get some updated photos of work in progress which I will post as soon as I can.
In the meantime here are some of the earlier photos. Not much to see at the moment.
I wanted the vents to look more real, so you can see my efforts and how I did them.
I also rescribed the panel lines.
Two things I did but have no pictures of are , I removed the horizontal stabilizers from the fuselage molding as it will be far easier to fill and sand the seam line in this area with them out of the way. I plan to mount them on brass rods in brass tubing so they can be positioned
The other thing I did was remove the intake ducting from the cockpit flor, extedned it and glued it to the intake lip. This allowed me to more eaily fill the seam on the inside of the lip where the two parts joined. My plan is to glue the lip and trunck to the upper fuselage first before joining the upper and lower fuselage halves. Hopefully this will make it easier to get a better fit on the lip and fuselage join line.
Anyway, that's it for now. I'll try to get more soon.
Carl - Attempting to Take my building to a whole new level
[ATTACH]18176.IPB[/ATTACH]
[ATTACH]18177.IPB[/ATTACH]
[ATTACH]18178.IPB[/ATTACH]
[ATTACH]18179.IPB[/ATTACH]
[ATTACH]18180.IPB[/ATTACH]
[ATTACH]18181.IPB[/ATTACH]
[ATTACH]18182.IPB[/ATTACH]
[ATTACH]18183.IPB[/ATTACH]
[ATTACH]18184.IPB[/ATTACH]
