Trumpeter 1/32 Mig3
  • Vaughan
    • Apr 2011
    • 3221
    Trumpeter 1/32 Mig3
    I made a start on the Mig a few days back and have almost completed the office with just some seat belts and instrument dials to add. This is a simple kit with only a 108 parts there's no engine to build but the office is very well detailed. The kit is up to Trumpeters usual standard with subtle panel lines and rivet detail. This is the first time I have attempted to make two models at the same time but I think it will work out ok alternating between the two. The Mig is a very small aircraft and its fuselage is only 2/3 the length of the Sturmovik that I'm building, its wingspan is even smaller than a Bf109.
    Vaughan
    [ATTACH]47396.IPB[/ATTACH]
    [ATTACH]47397.IPB[/ATTACH]
    [ATTACH]47398.IPB[/ATTACH]
    [ATTACH]47399.IPB[/ATTACH]
    [ATTACH]47400.IPB[/ATTACH]
    [ATTACH]47401.IPB[/ATTACH]
    [ATTACH]47402.IPB[/ATTACH]
    [ATTACH]47403.IPB[/ATTACH]
    • 22955
    Great work on the office Vaughan looking realy good
      Nice work mate, some steady hand work there, spot on.
      Andy
        you are brill at this painting lark,awesome start
        mobear
          I like it... great pit
          :flattered:
          Roman
          • colin m
            • 9040
            • Colin
            • Stafford, UK
            Looks nice Vaughan. I helped daughter No 2 build a 1:72 sale Mig 3, and that was small !
            • Vaughan
              • Apr 2011
              • 3221
              Thanks Guys. Here's a small update fuselage walls are painted and a dry fit with the office. Still working on the instrument dials and half way through making some seat belts. Here's a photo of the mig in comparison to the Sturmovik as you can see it really is small!.
              Vaughan
              [ATTACH]47459.IPB[/ATTACH]
              • yak face
                • Jun 2009
                • 14242
                • Tony
                Nice start vaughan, its a good kit,of a not very often seen aircraft. The only tip I can offer is this - when I built mine , I spent ages gluing in the etched hinges and pins in the wings only to find that they didnt really move after assembly and painting ! Maybe if I did another I would just glue the ailerons in and not bother with the P.E. stuff!Looking forward to seeing the build progress , cheers tony
                • Vaughan
                  • Apr 2011
                  • 3221
                  A little update instrument panel is complete and here's a dry fit in the fuselage. Still working on those seat belts.
                  Vaughan
                  [ATTACH]47801.IPB[/ATTACH]
                  [ATTACH]47802.IPB[/ATTACH]
                  [ATTACH]47803.IPB[/ATTACH]
                    Coming along nicely buddy.
                    Martin
                      • 22955
                      Great work on the cockpit Vaughan realy great
                      • MORIARTY1177
                        • Jul 2011
                        • 485
                        Lovely bit of detailing in the office there Vaughn, keep up the good work!
                        Regards
                        Chris
                        • Vaughan
                          • Apr 2011
                          • 3221
                          Have made a start on the under carriage and the wheel wells. Seat belts are finished and the next task is to close the fuselage halves.
                          Vaughan
                          [ATTACH]47994.IPB[/ATTACH]
                          • Vaughan
                            • Apr 2011
                            • 3221
                            Hi All
                            I thought I'd try a dry run with the fuselage which is made up of 4 separate parts plus the wings and under carriage. She's going to be one compact little plane.
                            Vaughan
                            [ATTACH]48011.IPB[/ATTACH]
                            [ATTACH]48012.IPB[/ATTACH]
                            • Vaughan
                              • Apr 2011
                              • 3221
                              A small amount of progress today the fuselage halves are together at last and the top engine cowlings are on. Next are the wings and tail planes. As you can see the tail wheel is well protected I learnt the hard way on several builds!
                              Vaughan
                              [ATTACH]48156.IPB[/ATTACH]
                              [ATTACH]48157.IPB[/ATTACH]
