I Swear, this Yank is Crazy!
I just didn't like having nice, big waist-bubble's and not being able to see through from one side to the other; the card-stock background pasted onto the hull just will not satisfy my compulsive desire for detail!
Of course, this means cutting into the fuselage, and therefore it must be re-inforced; the first step was to make a tear-drop frame from 3/32in balsa:
To have enough strength for this operation, the fuse between F6 and F8 must be planked:
Once the above-the-side-keel planks were in, I worked the starboard-side frame first, the hard way, without first wet-forming the frame, and had plenty trouble including grain-splits in the broad front edge:
I did the next one right (only broke it once while handling), and sprayed the frame with water to get it flexible, then used an elastic velcro catheter-bandage as a clamp for wet-forming (and forgot to put wax-paper over the hull):
Once dry, it was easy to glue to the hull; the same technique was used to clamp the glued frame, with wax-paper over the glued object:
Once sufficient areas have been strengthened, the hull could be cut open and part of former F7 could be cut away:
Cutting away the rest of the former and shaping it in some appropriate manner will wait for the last planks under the side-keel.
Having been bit by the "planking-fever" out of necessity, I don't know if the entire fuselage will be planked, or only major mod areas; I believe I will definitely tissue-cover the wings, and maybe parts of the fuse, maybe not!
Regards, John (p.s. more insanity to come!)
