Tamiya's 1/32 SpitfireIX
    • 18302
    I'm going to stick my neck out here and say go with the int.green.
    My last has alu on the inside, but thats only because I forgot to paint the darn things before glueing things together and in place. Being a mk I, I am going for the excuse that says didnt think they needed painting.
    Most of the restored spits have int. green on the inside of the UC doors. (of the four! replicas of JE*J three have green one alu!!! so looks like green is the flavour of the day)!
    That Merlin looks fantastic by the way!
    • stona
      • Jul 2008
      • 9889
      #62
      Thanks Ian, I reckon it's too light to be the interior green. Recently unearthed,documents call for all interior surfaces to be given a coat of grey primer followed by a coat of alumimium coloured cellulose laquer. The problem is the wheel wells are nowhere specified as being interior or exterior!
      Many people go with the underside colour as aircraft that had been resprayed (as this one certainly had been, by Johnson's own account) often don't appear to have had the area of the undercarriage masked meaning that wells,gear doors and undercarriage struts all got a coat of the under surface colour. This is supported by a lot of photographic evidence. When the single black port wing was introduced a lot of aircraft got a black gear door and wheel well. When it was revoked the same areas reverted to Sky. There's a famous photo of a line up of RCAF Spitfires in North Africa(which I can't find!) and they've all got azure blue undercarriages and wells.
      I have to say I'm leaning towards medium sea grey. I may mist it over a coat of aluminium to hedge my bets lol.
        Well, after sampling a small section and doing a global contrast change, I would say it is exactly the same tone as the wheel hub. Both are in the same light and both are virtually burned out to the same degree. Neither are totally burned out, you can see there is some grey tone in there. If they had both been totally burned out (bleached) to white then one could have been white and one black and you would not be able to tell the difference.
        So, I would say given the average amounts of greys and whites being very similar, they are the same colour or the same shade of colour. If it had been aluminium, it would have totally burned out. My guess is that if the underside is the skye blue then you are looking at either the same colour or a grey of similar tone. Having said that, he interior colour, although green, could in fact have a similar tonal range which I suspect it would have looked slightly darker in the grey areas than the wheel hub, which it does slightly.
        But then again, I cannot tell the difference between grass and concrete lol
          • 18302
          This is a great example as to how modelers of modern Aircraft, or armour for that matter have i easy. Full colour documentation of the real thing. The builders of anything prior to real colour film (of a dependabe sort) Have to rely on museums, which can also get it very wrong. Anoraks that know it all beacause the book they read said so. Then there is us lot. Sitting stairing at B/W photos having to guess the right colour.
          Our next best source are restored craft. They too are about as trustworthy of the metoffice.
          Interior green. Just ses how many shades of that you can see on different Spits that have been restored. The BSmatched paints that you can but are IMHO to dark: If you go by what you see on a museum or restored 'plane.
          If you can find these spits you will see that there is no common factor. And this is just regarding the UC doors!!
          AB 910 green
          BM597 Grey or alu
          MH434 green
          PL344 alu
          SM845 green
          TD248 green
          Oddly enough all the wheels appear to be nat allu.
          There are so many variation our job is not an easy one is it?!
          My mantra is if it looks good/right to you then its good. If some one says thats not right, the only logical thing to reply is; Prove it.
          Your plan of a dusting of undersurface colour over allu sounds to be a very good solution to the problem.
          right then enough of my waffle, I'm off to order some Interior green.
            • 18302
            Steve, Just found this. You ,and others might find it some use. Spitfires. Loads of 'em. Many of which it is just so easy to see the inside of the UC doors.
            Gallery
            • stona
              • Jul 2008
              • 9889
              #66
              Nice link Ian,thanks. You are quite correct about restored aircraft. The restorers face exactly the same problems that we do. They are making,in effect,a 1/1 model!
              The gear leg is another conundrum. They were removed and seviced frequently. I can't remember the "hours" but it wasn't a lot. This apparently involved soaking them in parafin which removed most of the paint. You could easily have an inner door one colour and the leg in aluminium. Not on JE*J as we know it was repainted shortly before Johnson acquired it......Phew!
              Graham your conclusion that the wheel hub cover and inner gear door match the underside colour actually supports the idea that the whole kit and caboodle are in medium sea grey. knowing that the aircraft was definitely resprayed just before Johnson got it and given the time frame it would be virtually impossible for it to be in anything other than the day fighter scheme (dark green/ocean grey over medium sea grey).
              I'll be spraying tomorrow,SWMBO permitting, so at least I can sleep on it lol.
                • 18302
                glad you figured it out!
                Some things are still hard to find out. Even on a site dedicated to Spitfires. I am seriously considering buying one of those Hayens manuals. You probably know anyway but they (Hayens) also do one for the Me 109!!!
                Just got a mail from my pusher that the Mk VII is in the shop! Bugger! Now I got two I want to buy!
                Hope that Mrs Stona is in the happier side of life tomorrow so you can spray.
                • stona
                  • Jul 2008
                  • 9889
                  #68
                  Quick update. I've fitted all the gubbins (wheel wells etc) into the lower wing and have attached the upper wing. The fit is,as usual,superb but I think it's safe to say that the trailing edge needs holding in place whilst the glue dries.
                  Photo evidence!
                  • stona
                    • Jul 2008
                    • 9889
                    #69
                    I never meant to get this far today but I had the fuselage done and the wings nearly done so I stuck them together!
                    A familiar shape emerges.
                    Still a long way to go.
                    • stona
                      • Jul 2008
                      • 9889
                      #70
                      Looks like.......a Spitfire!
                      Just a quick snap as modelling room will be shut up today due to imminent arrival of relatives including small people. A room full of delicate models,sharp tools and noxious substances does not make a very good play area!
                      Paint next week,well primer at least,with a bit of luck.
                        Looking good!
                        I had a look at the same kit here in SA, but at the equivalent of over 130-00 pound there is no way I will buy it :-(
                        Besides, I don't have the skill level yet to justify the kit LOL
                        Theuns
                        • stona
                          • Jul 2008
                          • 9889
                          #72
                          I've been doing lots of little bits and have primed the main airframe. I won't bore you with another picture of the same model in a different shade of grey!
                          I've had a go at the standing figure of Johnson as he is standing by his aircraft in my reference photo. I can't do figures so I thought I'd post a piccy of a headless Johnson in progress. My reference piccy was taken in July and Johnson is wearing shoes not boots. Mindful of our glorious english summers I did think of modifying the figures flying boots for wellies. SWMBO thought that was stupid so flying boots they will remain!
                          • stona
                            • Jul 2008
                            • 9889
                            #73
                            First paint is on! The leading edge yellow stripe,contrary to what you may have read elsewhere,was not 6" wide. Infact it was different for the Spitfire and Hurricane. I have a copy of the order dated 21/8/41 and for the Spitfire.
                            "(Yellow stripe) to extend from the wing tip to half way along the wing,measured from the wing tip with a width of 4 inches (i.e. 2 inches width on either side of the centre line of the wing edge)."
                            Since my subject had been recently repainted at an MU I expect this is exactly what it had. I'm not sure what they defined as the wing tip. The wing tip was a seperate structure and started well inside the navigation light.Most photographs seem to show the stripe finishing at the navigation light which may be an agreed compromise.
                            Anyway 4 inches in 1/32 is 3.175mm so that's the width of mask I shall attempt to cut.
                            The sky band infront of the tailplane was retained in this order at 18 inches wide,a relatively simple 14.3 mm.
                            Hoping to get the underside colour on this evening.
                              I love how thorough you are being with this labour of love, even though RAF is not your bag. Will you be using the new paints Tamiya made for this model Steve? Supposed to be (according to Tamiya) the most accurate. Tamiya are not really known about accuracy in colours though.
                              The yellow leading edge is really quite narrow isn't it? On my 1:48 Spitfire MKIX, I have just measured what I thought looked about right. On the top edge, it maxes at 5mm which equates a full band size over and under of 18 inches. A bit more than 4 inches lol
                              Will I be sanding it off and re painting.... Noooo but I will be more knowledgable for the next one. In 1:48, the yellow would only be a total, under and over of 2.1 mm, not a lot is it?
                              Learning so much from this Steve, cheers.
                                That's some beautiful progress there Steve
                                Keep us posted
