Venerable Revell 1/76 Lightning F6
    Decided to have a go at this as I thought I would have a dabble into the black art of scribing panel lines. First a look at the box and Sprues.
    [ATTACH]47988.IPB[/ATTACH]
    [ATTACH]47989.IPB[/ATTACH]
    [ATTACH]47990.IPB[/ATTACH]
    [ATTACH]47991.IPB[/ATTACH]
    Next I had a go at scribing, Picking something easy (not many lines and mostly straight ones) I did one of the tailplanes. One picture is with a slosh of primer on it and the other is bare plastic. The tailplane with sprue attached is the one with the raised panel lines. Now having seen them together I'm unsure whether to carry and try to do the rest or leave it as Revell intended. Any comments would be welcome.
    [ATTACH]47992.IPB[/ATTACH]
    [ATTACH]47993.IPB[/ATTACH]
    • HAWKERHUNTER
      • Feb 2012
      • 2074
      • Steve
      • Halifax, West Yorks.
      Havent done alot of rescribing as it is not the easiest of tasks to get right. The important thing is to get your first line absolutely straight or the rescriber will just keep going wrong. I think I would persevere with it as the raised panel lines dont look quite right. The good thing is if you dont get the lines right first time you can quickly just fill them in and try again until you get it right. Good luck with this one.
      • Dave W
        • Jan 2011
        • 4713
        Ive rescribed several models and definately think its worth doing.If you are finding it frustrating it might be an idea to do it along side another model.In other words, do a bit until youve had enough then carry on with the other model.i looked forward to seeing your build progress.
          Back with a little bit more, have done the tailplanes and port fuselage, although some of the lines are a bit grand canyon. Still we'll see what they are like when primed.
          Photo of progress so far. top fuselage half is yet to be done, at the bottom is my new flexible friend, with some masking tape on the back so it doesn't slip it is just right for the curvature of the body. Only 99p from W.H. Smiths. It is a tedious job though but not to bad as I just do half an hour every now and then.
          [ATTACH]48076.IPB[/ATTACH]
          • HAWKERHUNTER
            • Feb 2012
            • 2074
            • Steve
            Keep at it Barry. Its looking good and that looks like a good bit of kit. Might get one myself.
            • flyjoe180
              • Jan 2012
              • 13103
              • Joe
              • Earth
              I haven't yet attempted rescribing, so watching this with interest. Your efforts so far look good, and I agree that flexi-ruler looks like a great idea.
                Back again, i have spent the day pottering about and doing the odd bit of scribing. I find it quite therapeutic which from what I have read about the dark art is a bit strange, perhaps I need therapy. I have now finished scribing and just have a few (lot) of little mistakes to fill in. A few photo's attached.
                [ATTACH]48116.IPB[/ATTACH]
                [ATTACH]48117.IPB[/ATTACH]
                [ATTACH]48118.IPB[/ATTACH]
                  • 22983
                  Nice work on the rescribing Barry looking good
                  • colin m
                    • 9070
                    • Colin
                    • Stafford, UK
                    Glad to hear you stuck with the re-scribing Barry. I've only done one model completley, but the effort pays off come painting and panel wash time.
                      Looking good with the re-scribing.never tryed to do any scribing,but seeing yours I will have to give it a go sometime. Will keep on eye on this one.
                        Many thanks for the nice replies. Haven't done much lately as I have been away for a week. I found that rather than sand everything off and then scribe I scribed using the raised lines as guides which seemed to work ok then sanded and buffed everything. Slow easy and gentle is the way to go. I am now trying to do a bit of cockpit detail as its a bit bare in there.
                          Done a little bit more, cobbled together a basic cockpit and found some decals for a instrument panel, also made a couple of paper tubes with a little cone at the end to liven up the jet pipes. Have also found a mk2 seat but have no idea how I will be able to paint the details on it. Any advice on that would be appreciated.
                          [ATTACH]48529.IPB[/ATTACH]
                          [ATTACH]48530.IPB[/ATTACH]
                          [ATTACH]48531.IPB[/ATTACH]
                            Added a bit of detail to the u/c bays and landing gear, but have to put it on hold now as I'm off to Toronto and New York after the weekend and am now in a frenzy fo packing and unpacking to try and make the luggage weight, although I seem to only have a small part of one suitcase to sort out...
                            [ATTACH]48760.IPB[/ATTACH]
                            [ATTACH]48761.IPB[/ATTACH]
                              Hi, Back again after a lovely visit to the colonies, managed to avoid the jet lag by coming back on Queen Mary 2, a week of waiter service, magic. However I digress, a bit of primer and more sanding and filler to erase the mistakes, but the scribing looks a lot like the grand canyon in places. Maybe a bit enthusiastic with the scriber. Still it looks a bit better with a bit of primer on and the dry fit isn't to bad.
                              [ATTACH]50003.IPB[/ATTACH]
                              [ATTACH]50004.IPB[/ATTACH]
                              [ATTACH]50005.IPB[/ATTACH]
                              [ATTACH]50006.IPB[/ATTACH]
                              [ATTACH]50007.IPB[/ATTACH]
