Hi Steve. I found the same with the MGs. and took a similar remedial course. More problematic though, for me anyway, was finding that the shroud behind the instrument panel sits too high and fouls the cowl(covering the shroud) This is where I had to relieve both the underside of the cowl and shroud to allow the cowl to fit down into it's correct position. I managed it in the end but it was a bit trial and error. Maybe I went about it the wrong way but could'nt see a way around it. anyhow the end result may mean to hard fit this cowl in place which means never to see the gun mechs. again. Never mind. No doubt ,you will overcome this small problem if anyone can.
Very best of luck. Regards. Pete.
