And another Revell 1:32 Spitfire Mk 22/24
  • stona
    • Jul 2008
    • 9889
    #31
    Originally posted by \
    Looking good Graham, nearly there. That piece Steve mentions, I stuck it to the canopy first and then trial fitted the whole assembley (two parts !) to the fuselage. I found the location on the fueslage a bit iffy, but good on the canopy. Regards
    Colin M......
    You were lucky Colin. Mine fitted so badly to the fuselage I had to trim it to fit and then fair it in to the fuselage with putty! The screen butted up quite nicely to it,I used white glue to glue that which fills the little gaps anyway.
    • colin m
      • 9040
      • Colin
      • Stafford, UK
      #32
      Again, a strange part that could have easily been moulded into either the fueslage or canopy ! Matchbox liked to make things tricky. White glue, is that wood glue, PVA ?
      Regards
      Colin M......
      • stona
        • Jul 2008
        • 9889
        #33
        I would have used Kristal Klear or Gator's Grip depending which was closest to the front of the draw. Both look suspiciously like PVA.
