1/24 spitfire MK1A
  • colin m
    • 9066
    • Colin
    • Stafford, UK
    #61
    I see great things happening here.
      small update [ATTACH]56402.vB[/ATTACH]and now putting engine bits together [ATTACH]56403.vB[/ATTACH] i think i made it easier to put the mounts and stuff together because of cutting it off the fuse,for some reason yesterday i was agitated :bash: and only worked on it for a couple of hours
      mobear
      [ATTACH]58475.IPB[/ATTACH]
      [ATTACH]58476.IPB[/ATTACH]
        started to add pipe work to the engine next will be firewall wiring and hydraulic lines and electrical [ATTACH]56500.vB[/ATTACH]will this do for now lol
        mobear
        [ATTACH]58557.IPB[/ATTACH]
          The Mill looks really sharp Ole, impressive work for sure!
            i changed the engine detailing and colours also added rivet detail to the tank [ATTACH]56625.vB[/ATTACH][ATTACH]56626.vB[/ATTACH][ATTACH]56627.vB[/ATTACH],i like it much better now,just abit more weathering on the tank to give the rivets more detail,and thnx for the CA glue idea
            mobear
            [ATTACH]58673.IPB[/ATTACH]
            [ATTACH]58674.IPB[/ATTACH]
            [ATTACH]58675.IPB[/ATTACH]
              Hi Ole, Just caught up with this one, you've certainlly given yourself a challenge, looks great so far. Derek
                okay the bits and pieces of the engine are done [ATTACH]56648.vB[/ATTACH][ATTACH]56649.vB[/ATTACH].still need to put the exhausts on but that can be done later,also added weights over where the rear wheel will be[ATTACH]56650.vB[/ATTACH]
                mobear
                [ATTACH]58696.IPB[/ATTACH]
                [ATTACH]58697.IPB[/ATTACH]
                [ATTACH]58698.IPB[/ATTACH]
                  Love this build Ole.
                  Fantastic work so far mate!
                  Polux
                    This is coming along really well mate. Keep at it.
                    Kresten
                      • 22983
                      #70
                      A very busy not so little build going on there Ole, keep up the good work and keep those pictures coming
                        done the harness today,made the old style sutton harness,used old ribbon dyed it brownish,and attached it to a strut which was hard lol here you go some pics [ATTACH]56690.vB[/ATTACH][ATTACH]56691.vB[/ATTACH]also done a dry fit to see what it looked like heres some more pics [ATTACH]56692.vB[/ATTACH][ATTACH]56693.vB[/ATTACH]all comments wlcm
                        mobear
                        [ATTACH]58738.IPB[/ATTACH]
                        [ATTACH]58739.IPB[/ATTACH]
                        [ATTACH]58740.IPB[/ATTACH]
                        [ATTACH]58741.IPB[/ATTACH]
                          Loving this Ole ,had to go back and look at all the pics again ! Keep up the great stuff eagerly awaiting the next update,cheers Trey
                            like it... nice work so far
                              • 18302
                              You're giving this the beans Ole. Its looking very good indeed.
                                I'm still impressed .....
                                ...... that is all
