Flak Zielgerat 76, the V-1 Flying "Buzz Bomb"
    Got the odometer air-screw done, and gave the top-coat a go-over with stock Forest Green.
    The "propeller" was made of 1/32" brass, drilled, ground and filed, then gripped in the center with needle-nose pliers and the ends give an little twist.
    That now completes this model, except possibly a display stand (but I need to find a space to stand it in; that's the problem with these models, running out of room to display them!).
    Regards, John
    • flyjoe180
      • Jan 2012
      • 12946
      • Joe
      • Earth
      #17
      Wonderful work John, a simple yet effective model. Your paint work has come out tops too, nicely done.
        I cobbled up a display stand, but too tired to get fancy with a background for a photo, so improvised a hurried setup:
        The stand was cut from 1/4 inch x 2-1/2 inch craft oak from our local Lowe's "big-box" hardware/home-improvement store. Titebond II premium wood glue used for the stand, pylon pinned with short pieces cut from wooden-handled "Q-Tips." The same pins were used for the pylon to fuselage, with Crafter's Pick flexible glue used there (dries clear, adheres to painted surfaces).
        Regards, John
          • 22954
          #19
          Great work John that looks so good on the stand and the paint work looks spot on
          • flyjoe180
            • Jan 2012
            • 12946
            • Joe
            • Earth
            #20
            Superbly finished and displayed, a great build John.
