SE5a CONSTRUCTION BEGINNING TO . . .
  • Greyhead
    • Oct 2004
    • 581
    #346
    As I said earlier I intend to use the scale closed loop system for the aileron control and have been giving it some thought over the last few months; here are the results of my deliberations so far and any comments and / or suggestions will be gratefully received.
    I can see 2 main areas of concern; firstly the servo will have to pull all 4 ailerons with their associated friction and aerodynamic forces. Even though I’ll be using 2 servos, one will have to pull all 4 ailerons to bank left and the other one will have to pull all 4 ailerons to bank right. Secondly the cables may jump off the pulleys if there is any slack in the system.
    The first concern is easily, if not cheaply overcome. I will use “high torque” servos such as Futaba 3010 and a 6-volt battery pack; it’s the second concern that has been taxing the old grey matter!
    In a perfect world both servos would move the same amount and there would be no slack, but in the real world, using the differential mix, the servos will have to be set such that the “pull” servo moves less that the “release” servo to ensure that they are not stalled by working against each other but this obviously introduces the “slack in the system” that I want to avoid.
    Below is a sketch of the linkage I’ve designed which I hope will alleviate the problem, I will be making a test rig before I commit it to the model so please get your suggestions in quick before I start!
    This is how I hope it will work.
    To connect the aileron cables the spring is removed and both servo arms and rods moved out allowing plenty of slack to connect the “quick links”, the servos are then moved back to neutral to take up the slack and the spring replaced.
    To bank to the left the right servo pulls the bottom right aileron down working against the aerodynamic force, which will keep the cable tensioned, the top aileron is pulled down by a cable between the right ailerons and similarly aerodynamic force will keep the cable tensioned. A cable, via control horns protruding from the upper surfaces, connects the 2 top ailerons so the left ailerons are pulled up and again aerodynamic force will keep the cables tensioned. The cable from the bottom left aileron to the left servo is where the problem arises, here the aerodynamic force, which up until now has taken up any slack, will actually transfer all the slack to this cable run. Added to this, as explained earlier, the left servo has “released” more cable that the right servo has pulled, but because the rod can slide through the servo arm connector the spring will now take up the slack keeping the cable itself tensioned into the pulley.
    That’s the theory anyway!
    • wonwinglo
      • Apr 2004
      • 5410
      #347
      It is a clever system Grahame but why not use two servos mounted in each wing to drive the coupled upper and lower ailerons ? this will eliminate any slop allowing a more direct linkage,you can lead cables through the ribs down to a 'Y' lead,you may have reasons not to want this type of layout but it is worth consideration,especially in view of the powerful smaller servos available today.
      A small inspection plate or similar ensures that you can gain access to the link and servo maintenance itself.
      • Glider Guider
        • Oct 2004
        • 88
        #348
        This is a novel idea Grahame but I cannot visualise how it could work properly. For the spring to contract to take up any slack in the loop it must pull one, or both, servos from their true position as demanded by the control system. This would lead to the servo(s) ‘hunting’, I’m not sure if this would cause any damage apart from the extra drain on the battery but I doubt it is a good situation to build into a system.
        An alternative would be to only use a single servo and incorporate a spring in the loop, it would have to be sufficiently strong to counter the aerodynamic loads on the ailerons, however the use of springs without damping in any control system is prone to oscillation and would possibly (likely?) lead to aileron flutter – not a good thing.
        My thoughts were along the same lines as Barry’s but one step further and that is to use a servo for each aileron and have the cable control system just for show, the same idea as you are going to use for the elevator, this loop could then have springs in it to take up any slack with no adverse side effects that I can see, this would give good positive control of each aileron.
        Hitec do some nice servos specifically designed to fit into a thin wing but with plenty of torque. The down side would be the hole it would leave in your pocket – I know as I’ve just bought a pair for a high performance electric soarer I built over the winter.
        • Greyhead
          • Oct 2004
          • 581
          #349
          Thank you for the comments and suggestions, I’ll leave it a couple of days in case there are any more then reply to them all in one go.
          Today I’ve made these, 4 in all, from plastic tube, washers, pins and copper wire.
          They are attached to the inlet manifold so I think they are for injecting neat petrol into the engine during start up. Whatever they’re for they fill up the 4 holes in the cowl quite nicely!
          The trouble is they appear to hanging in mid air, I might have to add the inlet manifolds to the engine; one job just leads to another!
            Grahame, one concern with your proposed arrangement is that you are inducing a torque, all be it via a spring into the resting servo. This is going to cause the servo to work to maintain position, which it will do but it will be using battery power to acheive this.
            Although I see your idea working I think it will be heavy on battery use so I would undertake some very thorough and lengthy bench testing before committing to your arrangement.
            • Glider Guider
              • Oct 2004
              • 88
              #351
              I've just had another look at your diagram for the aileron closed loop system and realised that I had somewhat misunderstood it in that the bushes are not fixed to the actuating rods but are free to slide. This would certainly reduce the chance of stalling one or both of the servos but whether it would totally stop it would, I think, have to be a build it and see exercise.
              The servo I was talking about was the Hitec HS-125 BB which is only 10mm thick with obviously a bit more for the arm. Spec and picture at http://www.servoshop.co.uk/index.php...2c9a20bf255a40
              • Greyhead
                • Oct 2004
                • 581
                #352
                My starting point for the aileron control is that I’d like to use the scale closed loop system if at all possible because: it’s scale, I like a challenge and, considering that the pulleys etc will have to be included for scale fidelity anyway, if it works my proposed system will be easier to implement. So onto your comments, I probably didn’t explain it fully enough in the first instance but I think David now has the idea.
                The rods are not attached solidly to the servo arms but are free to slide through the holes in the connectors, when one servo moves towards the centre it pulls the rod because the connector is in contact with the spring attachment hook, this in turns pulls all 4 ailerons in the desired direction. The other servo moves outwards to “release” the cable but doesn’t actually push the rod; if there is any slack then the spring can pull the rod back through the servo connector. In practice I will ensure that there is always some slack by using the differential mix. The spring tension will not be imparted to the servos but will keep the cable tight into the pulleys, I hope!
                The possibility of aileron flutter is something I hadn’t considered, but thinking about it now as far as I can see the spring will only have any effect on the cable run from the last bottom aileron to the servo. When setting up a closed loop system using the Ackerman principle, the “released” cabled actually goes slightly slack and this doesn’t cause any problems so a bit of oscillation in this cable run shouldn’t cause too much trouble. Without having access to a wind tunnel I’ll just have to chance it!
                If my system proves not to work I will have to use individual servos in the wings; if to scale the wire joining the top and bottom ailerons will be too thin to use as a push rod so it’s either non scale joining wire or use a separate servo for each aileron, in either case space is a problem. The wing section is very thin; in practical terms I only have about 16mm in which to fit the servo and arm and I’m not sure I could get sufficient throw, especially as the aileron control horns are 23mm long, even using those very thin Hitech servos. I could possibly use the “bent rod and slot” method as used on scale models when the full size has hidden control horns but that’s a method I’ve never used before so would require some experimentation.
                Once again thanks for your input, time to start experimenting I think!
                • Greyhead
                  • Oct 2004
                  • 581
                  #353
                  The 2 fairings that cover the bungee cord used for springing on the axle will have to be hollow mouldings and they will have to be made in 2 halves so that involves making 4 identical pieces; I think a mould is called for!
                  First a plug is made from balsa, given a few coats of sanding sealer to produce a smooth surface and a box built around it.
                  Mould making rubber, a very soft material that melts at a relatively low temperature, is heated over the gas ring and poured into the box to produce the finished mould. The good thing about this material is that when you’re finished with the mould you just melt it down and use it again.
                  I really don’t like fibreglass / resin moulding so following Barry’s suggestion I tried paper and watered down PVA glue. To get the paper to conform to the shape I had to cut it into strips, it was thoroughly soaked in the glue then 3 layers applied in herringbone fashion. I was surprised just how quickly it set, it can be removed from the mould in a couple of hours and although not thoroughly dry it holds the shape.
                  This was my first attempt; I did things slightly differently for the subsequent mouldings in that I tore the paper into strips rather than cut it and I made doubly sure there were no air pockets under the first layer before proceeding with the second. This first attempt has been scrapped but shows up the herringbone pattern well, using the torn paper the joins are a lot less evident.
                  • Greyhead
                    • Oct 2004
                    • 581
                    #354
                    Making these paper mouldings has been a bit of a steep learning curve for me, I think it is really more suited to covering the outside of a shaped form rather than using a female mould as I’ve done, but I have to say I’m happy with the results, which are both light and sufficiently strong. After the pieces had dried overnight the edges had deformed somewhat becoming concave; this was easily remedied by holding them in the correct shape with a balsa template and then heating with the hot air gun, this softened the glue which then hardened and held the correct shape.
                    As I’m just learning this technique I decided to work on one fairing before I started on the second.
                    I wasn’t sure if the fairing would fit in one piece, as it does, or have to be left as separate halves, so I did the trimming to fit before joining them, which made things a bit more awkward; hopefully the second will be easier. Once again I’m not trying of a perfect finish, being in such a vulnerable position I’m certain they soon ended up with a considerable number of dents and scratches.
                      For a first attempt Grahame they look fine to me. I always find it interesting to see what new techniques you are going to come up with to tackle a specific challenge.
                      • wonwinglo
                        • Apr 2004
                        • 5410
                        #356
                        Have often thought of trying that rubber moulding material Grahame,did you get it from Alex Tiranti ?
                          Just wondering,
                          I am sure a home built VacForm Mould would have done this nicely and a lot less messy too...just another suggestion.
                          I have one of these and it just plugs into a standard Hoover to do the Vac Forming when required.
                          I bought a basic kit one from the old MAP Plans service years ago and eventually finished it for use, great easy tool to use. Very Cheap to construct from scratch too.
                          Regards...Mark.
                          • Greyhead
                            • Oct 2004
                            • 581
                            #358
                            You never stop learning in this game!
                            Barry
                            I bought the “moulding rubber” some years ago from my local model shop; I originally used it to make rubber mountings at the wheel spats to wing joint on a Stuka. As with most things it has more uses than the one it was designed for.
                            Mark
                            A vac-forming machine sounds like a worthwhile investment at that price (very cheap!!), any chance of uploading a sketch with sizes / materials used etc.; daren’t ask for a “scan”, that would really upset John!
                            Grahame
                            When cutting out the clearance holes for the undercarriage legs it became clear that the thickness of the mouldings wasn’t very even to say the least; I’d obviously used less layers of paper in some places, so for my next attempt I’ll use alternating layers of white and coloured paper, this should even things up.
                            The “join” is simulated using litho plate embossed with a row rivets and a row of screws, faired in with cellulose stopper. At first I tried using just one strip with both rows embossed and a score line down the middle but I couldn’t form it around the fairing without loosing a lot of the embossed detail, so I used 2 separate strips; this has actually worked out better in the end because the “join” now isn’t perfect, just as the full size. The finished fairings are painted with silver Solarlac so that they will appear to be metal when the PC10 is weathered.
                            I’m not too happy with the embossed screw detail but at the moment everything is silver, maybe it’ll look better when it’s coloured and weathered, if not I’m sure I’ll be able to think of some way to improve matters.
                            • Greyhead
                              • Oct 2004
                              • 581
                              #359
                              I’ve made a test rig to check my idea for the aileron linkage.
                              The hinge point for the top lever is such that there is “built in” slack in the system as it moves from the neutral position; the spring is provided by a rubber band.
                              This is a photo of the left hand servo after it has pulled the cable; I’ve marked the rod at the contact point with the servo connector.
                              And this is a photo of the same servo after the right hand servo has pulled the cable; the rubber band has taken up the slack as evident by the mark on the rod. Of course the exact opposite happens with the other servo
                              The system certainly works, keeping tension in the cable, I’m sure it will work a lot better when I’ve made a proper engineering job of the actuating rods and the sliding bearings.
                              • wonwinglo
                                • Apr 2004
                                • 5410
                                #360
                                Excellent test rig Grahame,great to prove that things really do work as planned.
