Time for the ailerons; I’m not going to use the “usual” modelling aileron-to-aileron linkage method of a 2mm threaded rod with quick links for at least 2 reasons. At this scale 2mm rod is just too big a diameter and no full size aircraft that I know of uses anything remotely resembling a quick link!
The brackets are bent at 90º for attachment to the aileron spars and consist of a brass bush soldered to thin tin plate with a 1/16th ply “spacer”.
A bracket epoxied and bound to the spar.
The ailerons have one side and the leading edges covered and are then attached to the wings before the other side is covered. A twist of tinned copper wire soldered to the hinge wires and expoxied to the LE acts as a keeper and in this case also additional strength for the control horn.
When it comes time to fit the aileron-to-aileron link wire I’ll either cut an “inspection hole” (the full size has lots of them) in the appropriate panel or remove the panel altogether; I’ll decided which at the time, but at the moment I’m leaning towards removing the entire panel for ease of access.
