Nice build
Spitfire Mk. VI
Guest -
Really appreaciate your comments mates, thank you.
I retouched the camouflage, completed the painting and started applying decals. Unfortunately also the new decals sheet sent by italeri to replace the bad printed in the box isn't properly aligned. This is less evident on the rounders but quite visible on the tail codes. I will have to invent something for the code (and try to remove the silvering).
[ATTACH]75411.IPB[/ATTACH]
Thanks for looking.
Francesco
Guest -
Thanks Joe, probably I just been unlucky.Originally posted by \That's pretty unusual for Italeri to have dodgy decals. It's looking great so far, keep up the good work and it'll be done before you know it
However, better than this I can't do. Few small touches (mirror, smoke, antenna, ecc.) then it's complete.
[ATTACH]75445.IPB[/ATTACH]
Francesco
Guest -
