Nimrod MR2 - Airfix 1/72
  • rickoshea52
    • Dec 2011
    • 4079
    • Rick
    I'm building this in slooooooooooowwwwwwww time.
    I am doing a diorama of a Nimrod just as No. 3/4 engine has started in preparation for a see-off with the 60KVa Houchin, assorted GSE and lineys on the scene - circa 2002 (my experience of Nimrod APU starts were; APU-3-4-2-1 engines). Or, if I can bothered building a modified BW Models bowser, a see-in, again with appropriately positioned lineys and GSE. That's why the bomb doors are closed...not to mention the fact that the moulded bomb bay is awful. If I do one with the bomb doors open I will use the Alleycat kit, but this isn't faultless either.
    I have the Flightpath diorama kit and their 25KVa Houchin, but I am convinced that they have made a mistake and it's a sixty. I'll consult my RAF GSE expert for clarity, i.e. my wife. Maybe some MT if I can find something suitable and easy to build.
    The basic colours are done with the bomb bay seal, Doppler panel and 4a tank wheel fairings picked out in black - the doppler panel (big square thing behind the nose gear bay) has been wiped down with a cotton bud to replicate the fibre glass finish that this panel sometimes wore. The finlets need a coat of black for the anti-erosion strips. It's been given a first coat of Humbrol Clear which I am not convinced with.
    And for the more observant, I STILL have another Nimrod under construction depicting a jet in Minor maintenance in AMF RAF Kinloss circa 1999 -2003.
    [ATTACH]79744.IPB[/ATTACH]
    [ATTACH]79745.IPB[/ATTACH]
    [ATTACH]79746.IPB[/ATTACH]
  • Alan 45
    • Nov 2012
    • 9833
    I have one of those and it looks a decent kit so I'll be keeping an eye on this
      • 22851
      Nice Rick I also have one of these
      • rickoshea52
        • Dec 2011
        • 4079
        • Rick
        I bunked off while the in-laws were around to do the tedious task of masking the finlets ready for brush painting the anti-erosion strips on their leading edges. Then it's the even more tedious task of applying decals to a large aircraft!
        [ATTACH]87091.IPB[/ATTACH]
        • rickoshea52
          • Dec 2011
          • 4079
          • Rick
          Then I remembered that the AAR probe also needed done.
          [ATTACH]87092.IPB[/ATTACH]
          • rickoshea52
            • Dec 2011
            • 4079
            • Rick
            I finally settled on an identity for my Nimrod - XV235 - with no fancy additional squadron markings or wing pylons. During my time in Aircraft Maintenance Flight at RAF Kinloss I worked on just about every Nimrod MR2 that was in service from 1992-95 & 1998-2002. I have a definite recollection of working on this jet during my second tour.
            Somebody was asking in another thread what is the least enjoyable aspect of modelling and for me it has to be applying decals. I have only applied the roundels, fin flashes and tail numbers so far but the remaining decals fill me with dread at the thought of many evenings of cutting, dipping and dabbing. The paradox of this aversion is that of all the things that make up a model, the decals are the build step that really starts to bring a model to life.
            [ATTACH]87191.IPB[/ATTACH]
            • flyjoe180
              • Jan 2012
              • 12668
              • Joe
              • Earth
              Looking good Rick, and nice to see you have a Nimrod with which you have a personal connection.
              • rickoshea52
                • Dec 2011
                • 4079
                • Rick
                Actually Joe, I can probably lay claim to having a connection to almost all Nimrods with the exception of the AEW's. I have serviced wheels, brakes, actuators, chemical toilets, LOX pots and control columns from my time in the bays at Kinloss. A little known difference between the R1 and MR marks is that the R1 has a bigger chemical toilet. Make of that what you will!
                • Alan 45
                  • Nov 2012
                  • 9833
                  Looking good rick , how does this kit go together ? I have this for my British Cold War jets collection and it would be very helpful to know of any pit falls I may encounter
                  • rickoshea52
                    • Dec 2011
                    • 4079
                    • Rick
                    Looking good rick , how does this kit go together ? I have this for my British Cold War jets collection and it would be very helpful to know of any pit falls I may encounterCheers
                    It goes together quite well actually. The flight deck is a bit sparse but then the windows are tiny and you can't see much anyway. The fit around the "duck's arse", the curved section at the back of the bomb bay doors was filled and I lost some of the surface detail here. The wings to fuselage join took a bit of work to glue together as they kept splitting away. The nose gear compartment is also a poor representation of the real thing just being a box. The Nimrod Nose gear bay has an inclined rear bulkhead and lots of other detail in the roof of the compartment.
                    The bomb bay is also pretty rubbish, I have an alley cat resin version and although far superior to the kit offering it has one glaring error - the hyd bay panel is 90 degrees out. There is also an error in the instructions when it comes to the main landing gear doors, or D doors as they are called in the RAF. The instructions show them open when they should be closed. They are only open during the gear extension/retraction sequence or while on the ground for maintenance.
                    • Alan 45
                      • Nov 2012
                      • 9833
                      It goes together quite well actually. The flight deck is a bit sparse but then the windows are tiny and you can't see much anyway. The fit around the "duck's arse", the curved section at the back of the bomb bay doors was filled and I lost some of the surface detail here. The wings to fuselage join took a bit of work to glue together as they kept splitting away. The nose gear compartment is also a poor representation of the real thing just being a box. The Nimrod Nose gear bay has an inclined rear bulkhead and lots of other detail in the roof of the compartment.The bomb bay is also pretty rubbish, I have an alley cat resin version and although far superior to the kit offering it has one glaring error - the hyd bay panel is 90 degrees out. There is also an error in the instructions when it comes to the main landing gear doors, or D doors as they are called in the RAF. The instructions show them open when they should be closed. They are only open during the gear extension/retraction sequence or while on the ground for maintenance.
                      Thanks rick that's a big help so really it's just the same sort of problems we get with many airfix aircraft and thanks for the info on making it look a bit better I appreciate it
                      • rickoshea52
                        • Dec 2011
                        • 4079
                        • Rick
                        No problem.
                        Another tip to share is the bomb door positions - there are three, open, closed and stores loading. When they are closed they are closed for flight, taxying and towing. When parked the doors are left open and locked. In these two positions the forward and rear doors open as one even though they are not physically connected.
                        The final door position is stores loading and as expected this is only ever done on the ground for loading the bomb bay. There is no clearance when on the ground so the doors flare to near horizontal however the forward doors flare more than the rear doors due to profile of the wings. The stores loading controls are on an access panel on the forward left pannier close to the RT and GPU service panels.
                        If you were doing this jet with the doors open you should note that from arounf 1995 the bomb door insulation was removed from the inside surface of the doors. This was a black foam material and was notorious for getting damaged and ripping off in flight. For post 1995-ish MR2's paint the inside gloss white, black for before then. And of course, the R1's never had bomb doors.
                        • Alan 45
                          • Nov 2012
                          • 9833
                          No problem.Another tip to share is the bomb door positions - there are three, open, closed and stores loading. When they are closed they are closed for flight, taxying and towing. When parked the doors are left open and locked. In these two positions the forward and rear doors open as one even though they are not physically connected.
                          If you were doing this jet with the doors open you should note that from arounf 1995 the bomb door insulation was removed from the inside surface of the doors. This was a black foam material and was notoriouss for getting damaged and ripping off in flight. For post 1995-ish MR2's paint the inside gloss white, black for before then. And of course, the one never have bomb doors.
                          Cheers rick for the info
                          • rickoshea52
                            • Dec 2011
                            • 4079
                            • Rick
                            Port upper wing done. I don't remember the refuel squares being this big though.
                            [ATTACH]87198.IPB[/ATTACH]
                              • 22851
                              Looking good Rick
