1/72 Hasegawa RNZAF Bell UH-1H Iroquois
  • flyjoe180
    • Jan 2012
    • 12956
    • Joe
    • Earth
    I started this one as an aside project in April last year. The intention was to model it on an RNZAF example from the 1980s in SEA camouflage as was the standard then. The Hasegawa UH-1H kit is not a good kit to build by today's standards. It lacks detail and some shape and has rivet rash. I have seen one built here before in Macedonian colours and was aware of the issues. I bought this one decades ago with some basic RNZAF markings. I have the Italeri version which is a much more modern and accurate kit, which I will build later on to represent the last scheme that the RNZAF Iroquois are wearing as they are retired. Any way this build so far:
    The objective:
    [ATTACH]83883.IPB[/ATTACH]
    The kit:
    [ATTACH]83884.IPB[/ATTACH]
    As I said this is a rather basic kit by modern standards with some issues, but overall it fits well and builds up into a reasonably clean airframe. One aspect which requires very careful planning is that the windows are fitted from the outside of the model. The top windows were painted with Humbrol clear green which I had used previously on the RAAF UH-1B model. Wire cutters and other aerials were not fitted to RNZAF Iroquois until the mid to late 1980s so I omitted them:
    [ATTACH]83885.IPB[/ATTACH]
    [ATTACH]83886.IPB[/ATTACH]
    Primed and ready for paint (this was where I picked this up in 2014 as I struggled for motivation with the Sea Harrier):
    [ATTACH]83887.IPB[/ATTACH]
  • flyjoe180
    • Jan 2012
    • 12956
    • Joe
    • Earth
    Then I moved on to the painting stage in between going crazy with the Sea Harrier.
    The painting plan drawn over a 1/72 scale drawing. The SEA scheme has three colours, a tan (FS30219), a light green (FS34102), and a dark green (FS34079):
    [ATTACH]83888.IPB[/ATTACH]
    First I painted the tan in the relevant areas, then the tan was masked off and the light green was applied. Then the light green areas were masked on top of the tan already blanked off and the dark green applied. What you get is a maze of sausages and tape:
    [ATTACH]83889.IPB[/ATTACH]
    [ATTACH]83890.IPB[/ATTACH]
    When all that was done and dried the masking was removed and I had a three colour SEA scheme as hoped for.
    • flyjoe180
      • Jan 2012
      • 12956
      • Joe
      • Earth
      Then I had to think about some detailing. The RNZAF Iroquois carried a zig-zag HF aerial on both sides of the tail boom until the mid to late 1980s when they were modified with a straight aerial on the port side only. I had an idea and took a risk with a drill and some 15-Amp fuse wire.
      [ATTACH]83891.IPB[/ATTACH]
      It worked fine. I drilled straight through the boom sides and threaded the wire through and snipped it to length. In this scale this will give the wires plenty of surface to hang onto without fear of breakage as I would have had with plastic scratch built prongs. Then I painted them black and got on with the rest of the model.
      I bought some relevant decals from a guy here in New Zealand going by the name of Oldmodels Decals. He prints specialist NZ subjects which is a very good service. However the digital decals were rather thick and some refused to adhere at all. Inthe end I used some of his decals with my own spares and for the RNZAF roundels used another NZ company, Ventura. The No.3 Squadron badges on the doors and the Maori symbol on the tail fin were all that I really needed from the Oldmodels decals anyway.
      As you can see some of the decals were out of register. I had to paint them in as carefully as I could. This is definitely one down side of 1/72 scale.
      [ATTACH]83892.IPB[/ATTACH]
      [ATTACH]83893.IPB[/ATTACH]
      [ATTACH]83894.IPB[/ATTACH]
      [ATTACH]83895.IPB[/ATTACH]
      [ATTACH]83896.IPB[/ATTACH]
      • flyjoe180
        • Jan 2012
        • 12956
        • Joe
        • Earth
        Aerial wires were next. The tail fin VHF aerial (5 Amp fuse wire):
        [ATTACH]83897.IPB[/ATTACH]
        The boom zig-zag HF aerials (10 Amp fuse wire):
        [ATTACH]83898.IPB[/ATTACH]
        [ATTACH]83899.IPB[/ATTACH]
        Painted them in white:
        [ATTACH]83900.IPB[/ATTACH]
        [ATTACH]83901.IPB[/ATTACH]
        I think this was a good solution to the problem. The fuse wire was easier to apply and handle and paint than some fishing line I intended to use initially.
        So in the end I used 5-Amp wire for the tail fin aerial, 10-Amp wire for the HF aerials, and 15-Amp fuse wires for the prongs that hold them. Just as well we don't use fuse wire in the house any longer because there isn't much left.
        And this is where we are at the end of play today:
        [ATTACH]83902.IPB[/ATTACH]
        Next up is a wash around those engine vents and nacelles, a flat varnish and then the application of some navigation lights. I hope you enjoyed this, apologies for the 'all at once' thread.
        • peterairfix
          • Jul 2012
          • 11144
          Nice work on that bird so far i have yet to do one of those but keep up the good work.
          Peter t
            Wowww looking good so far
              Looking very good so far Joe
              • monica
                • Oct 2013
                • 15169
                good job so far Joe,
                  • 22954
                  Like the rest have said Joe looking good
                    Love it Joe! Clever use of the fuse wire & excellent multi colour painting in such a small scale. As with Ian's build, it's .....
                    [ATTACH]83908.IPB[/ATTACH]
                      That's looking nice Joe.
                      • flyjoe180
                        • Jan 2012
                        • 12956
                        • Joe
                        • Earth
                        Thanks you lot, I am actually enjoying this build very much, a nice change. More to come yet!
                        • Lee W
                          • Feb 2014
                          • 4700
                          • Lee
                          • Sherborne
                          It's looking good Joe
                          Lee
                          • flyjoe180
                            • Jan 2012
                            • 12956
                            • Joe
                            • Earth
                            I have completed the Iroquois. I gave a light wash around the engine vents and intakes, applied Humbrol Matt Cote via airbrush (which was very effective and pleasant to use), and highlighted a few areas and applied navigation lights. Completed build thread to follow shortly.
                            [ATTACH]83955.IPB[/ATTACH]
                            [ATTACH]83956.IPB[/ATTACH]
                            • Vaughan
                              • Apr 2011
                              • 3221
                              A great build Joe on such a small scale I don't know you guys work at that scale I struggle with 1/32. Nice camo that matt coat has worked really well.
