Hi all,
Not sure if this is in the correct section as it includes a space craft and a diorama - mods please move as you see fit.
Just started this build and it's taking me way out of my comfort zone of building cars. Hope you think a build log will be of interest. Will be depicting the recovery of Columbia CM from Apollo 11. 66 was deployed from USS Hornet approximately 13 miles away.
This will be my helicopter, first diorama, first time working with figures and the first build where the interior and glass is fitted and painted prior to painting the body/ fuselage.
I have to do lots of research regarding colours etc. but I have a couple of, potentially many more to come, questions for the assembled experts;
1. The box art shows the main landing gear retracted but the instructions show it deployed - which is correct?
2. 3 sets of main rotor blades are supplied, folded, extended static on ground (drooping downwards) and in flight (curved upwards) - is the latter correct?
3. Would the exterior finish be gloss, matt, or semi sheen bearing in mind that the eyes of millions of TV viewers worldwide are watching the return of probably the most significant event in modern history?
4. The raft, flotation ring and flotation balloons are moulded in a rubbery type substance - how does one prime and paint these successfully?
Any and all answers and comments most graciously received.
Here are some photos.
