I've been using alclad but it's a filler too. Does a great job though but smelly. I wear a mask and paint in the shed so no real issue anyway. Going to see about trying Valley again but it depends on what I'm painting on top. Its so easy to just prime everything at once with a lacquer based primer. Can't decide haha.
AH-64D apache Longbow : 1/48 : Hasegawa
Guest -
I find you cannot use a laquer based filler over Vallejo (OK under) as it softens the paint.Originally posted by \I've been using alclad but it's a filler too. Does a great job though but smelly. I wear a mask and paint in the shed so no real issue anyway. Going to see about trying Valley again but it depends on what I'm painting on top. Its so easy to just prime everything at once with a lacquer based primer. Can't decide haha.
But I have used over Stynlrez My Surfacer 500. Before I had to use Vallejo Putty FIller
over Vallejo paint.
Mr Surfacer which can be wet and dried over Stynlrez with out breaking away or
affecting its surface.
I started with Enamels but felt so sick with the smell I near gave up model making
until I experimented with water based Acrylics. Living in a flat now it is only practical
to use the water based products. I have found, so far, that I can achieve all that I
want with these.
LaurieComment
Guest -
Good idea Dougie I use 500 most of the time the 1000 and 1200 are more primers Nice advantage is thatOriginally posted by \I do need to try some Mr surfacer filler
the filler is about the same hardness as the plastic When sanding you are sanding both plastic and filler at
the same rate giving a seamless joint which as said before sands to a feather without breaking away
As I have mentioned in the pictures I build in layers The filler will drop into a crack leaving a mountain each side
Can give the impression after a couple of coats that the crack still needs filling. Next time I am going to use tape
either side which will save a lot of sanding (PS remove tape immediately after applying to avoid a right mess)
Others use IPA to smooth but for me I have not found success. I use an old stiff paint brush to put the stuff on
cleaning up with IPA.
Right away must see how Hull City are getting on.
LaurieComment
Brilliant little shaker! What a great idea! I'm guessing it works well at sanding off the small,bits?Comment
Only very very small bits Dave. Advantage where as I use wet and dry paper to sand the largeOriginally posted by \Brilliant little shaker! What a great idea! I'm guessing it works well at sanding off the small,bits?
plastic bits it is very difficult to prepare all those weird and small pieces. Just take off that horrible
shine to give a grip for the primer
Figures are a good example Until I found this method with the continual handling while
painting figures the primer wore off.
LaureiComment
Sounds perfect. I always have problems with getting paint to adhere, wether I wash it or not!
I'll have to make one of these!Comment
I use just plastic containers with the clip on tops Got to be a good fit as bird grit all over the place is not fun (unless you have a Budgie).Originally posted by \Sounds perfect. I always have problems with getting paint to adhere, wether I wash it or not!
Also have a cheap "Dentist's" flat bed (about 4" diameter) with vecro on the bed and container. Put it on there for 5 mins "lovely job".
Thanks Ian and Joe for your kind remarks.
LaurieComment
Whoops should have said that the Dentist's flat bed is a small vibrating table.Originally posted by \I use just plastic containers with the clip on tops Got to be a good fit as bird grit all over the place is not fun (unless you have a Budgie).
Also that 3 different sized containers.
And count the objects you put in and count them out at the finish just as Brain Hanrahan counted out and in the Shahs.
LaurieComment
A little bit of progress. The artistic bit next and the most interesting for me.
[ATTACH]122968.IPB[/ATTACH]
[ATTACH]122969.IPB[/ATTACH]
[ATTACH]122970.IPB[/ATTACH]
[ATTACH]122971.IPB[/ATTACH]
[ATTACH]122972.IPB[/ATTACH]
[ATTACH]122973.IPB[/ATTACH]
[ATTACH]122974.IPB[/ATTACH]
[ATTACH]122975.IPB[/ATTACH]
