Italeri 1/48 AH-64D Longbow Apache
  • minitnkr
    • 7807
    • Dayton, OH USA
    #31
    I would add filler to all the inside walls then trim/file/sand to suit. Then clean up the outside as needed. PaulE
    • scottie3158
      • 14635
      • Holbeach
      #32
      Chris,
      Your doing a great job of licking this in to shape.
        Thanks all.
        I think I know what I'm going to do, thanks especially to Paul for bringing me back to starting from a simple starting point!
        • yak face
          • Jun 2009
          • 14309
          • Tony
          #34
          Nice work on fixing the misaligned panel lines chris . The exhausts look like another poorly moulded PITA , good luck with sorting them , cheers tony
            So...I have been agonising over these exhausts since my last post and what by any measure would be considered a disproportionate amount of time given the object.
            I started out with Paul's inspired idea to fill them and shape them, which I did and made mess of it.
            So I thought I might fill them completely and make a template, then drill them out by hand. The logic being the drilled holes would have a more uniform profile and the template would ensure consistency.
ID:	1145247Click image for larger version
ID:	1145248Click image for larger version
ID:	1145249Click image for larger version
            But it didn't go as I had planned or hoped and the result is still cack-handed.
            Then I remembered Bobs (Bowcat) latest acquisition in the form of the drill. I have a low torque 1/4" driver for ikea furniture, so I bought a 1/4" chuck for it.
ID:	1145252Click image for larger version
            But this too messed up the holes.
            So this is mainly a story of woe, misadventure and starting from scratch.
            I'm going to take Jims advice and make new face plates!
              I’m going to finish these up as they are and move on. Much happier with this result. Not perfect but good enough and need to get on with it!
ID:	1145317Click image for larger version
              • scottie3158
                • 14635
                • Holbeach
                #37
                A great improvement on what you started with.
                • adt70hk
                  • Sep 2019
                  • 10553
                  #38
                  Chris
                  Well done for persevering. I think I would have given up.
                  ATB.,
                    Thanks chaps.
                    I hope it’s an improvement. Couldn’t be worse (could it)?
                    • flyjoe180
                      • Jan 2012
                      • 13100
                      • Joe
                      • Earth
                      #40
                      You have much patience Chris. Looking at it, and if you haven't already lost the will to deal with this PITA, would it be an option to cut off the face, and precut styrene sheet faces onto the exhaust box? Having said that, it looks like once you smooth them down they'll look okay under the dark OD or gun metal (?) colour.
                        Hi Joe. That is the solution I have implemented...great minds eh!
                          I've been pretty busy this morning.
                          Before I could even consider fitting the sponsons or the engines I needed to evaluate the 'wings'. Unsurprisingly the fit was less than ideal.
                          The main problem here, and is a consistent problem, is that the rivet heads and panel lines are moulded underneath the mating area, so I took all these off with a flat headed blade.
                          Next I removed the locating tabs and using 600 grit wet and dry laid on a flat surface I sanded the face flat.
                          Next I finished up the engines, added the intake cover plate and blended it in. I also needed to graft in some plasticard to fill a void where the intake part was shorter than the engine housing.
                          The wings and the sponsons were fitted in one and then the engines were added.
ID:	1145373Click image for larger version
ID:	1145374Click image for larger version
                          There is going to be a decent amount of filling and shaping around the sponsons, particularly around the front, the wings and undersides.
                          It is beginning to look like an apache though!
                          • yak face
                            • Jun 2009
                            • 14309
                            • Tony
                            #43
                            Its putting up a fight isnt it chris , but youre winning so far , keep at it mate , cheers tony
                              Cheers Tony. I feel like I’m fighting it to be honest, it hasn’t done a great deal wrong. It is how it was meant to be and I’m asking it to be something else!
                              Enjoying it though! A different subject, a different challenge. 1/72 doesn’t offer up this kind of thing in the same way so it’s a nice change.
                              The canopy is the next challenge...you’ll see why soon!
                                Continue working on filling and finishing in prep for paint.
                                I hadn’t anticipated this much work!
ID:	1145840Click image for larger version
ID:	1145841Click image for larger version
ID:	1145842Click image for larger version
ID:	1145843Click image for larger version
