MH-53e, HC-4 Sigonella - Italeri 1/72
  • monica
    • Oct 2013
    • 15169
    #76
    Outstanding work Francesco, great detail, i think it looks good i was going to say about the tab, but after looking should be there
    last one on the right shows it , leave it be its great
      Thanks Monica.
      Faded a bit the blade, a bit more on the cover. Good for now, I will take a couple of days to consider this result then may do the other blade too.
      [ATTACH]79557.IPB[/ATTACH]
      [ATTACH]79558.IPB[/ATTACH]
      Francesco
      • yak face
        • Jun 2009
        • 14237
        • Tony
        #78
        Stunning work Francesco , simply superb attention to detail, cheers tony
          Thanks Tony, we're trying our best here
          Francesco
          • flyjoe180
            • Jan 2012
            • 12946
            • Joe
            • Earth
            #80
            I think you have blended it well by fading the rotors and hub. Great work Francesco.
              Thank you Joe
              • eddiesolo
                • Jul 2013
                • 11193
                #82
                Wow, Francesco, you you must have macro-eyes for that level of detail in 1/72. The scratch work is awesome, the fading/salting looks spot on to me.
                Just amazing.
                Si
                  Let me say thank you with a small update.
                  The main rotor is now complete (just few scratches to be fixed and a couples of tubes to reglue).
                  I moved my attention to the tail rotor, especially in the pitch system which not reproduced in the kit. To represent it I used the pitch levers from Eduard PE bending them a little and shortening the links, then I scratched the shaft (missing) and protection for the levers (totally wrong).
                  The result you can see below together with the real one.
                  [ATTACH]79928.IPB[/ATTACH]
                  [ATTACH]79929.IPB[/ATTACH]
                  Francesco
                  • Wong Ryan
                    • Mar 2014
                    • 560
                    #84
                    Top notch. The interior looks like the real thing !!!
                    And to top it off, this is 1/72 scale !! Great work.
                    • flyjoe180
                      • Jan 2012
                      • 12946
                      • Joe
                      • Earth
                      #85
                      More enhancement, looking good Francesco. All this attention to detail is going to pay off for sure.
                        • 18302
                        You must have very good eyes, Francesco. Really good work the level of detail is amazing.
                          Thank you mates.
                          I'm closing the fuselage today, I need to speed up as it's already three months since I started it (with the Sherman in between).
                          Not so good Ian, not so good.
                          Francesco
                            Happy Sunday mates.
                            Just to let you know I'm alive and modeling.
                            Current status:
                            • fuselage closed
                            • added third arm to the swash plate (missing in the kit!)
                            • moved handrail on the roof (straight in the kit, but with the front shifted to the right in reality)
                            • modified APU air intake (front too thick, back closed in the kit)
                            • modified air intake over turbine 3 (too rounded in the kit)
                            • modified support for the bottom cranes (should be attached on center line and closed when not in use)
                            • added some PE
                            • added skid training arm to the cabin roof
                            • shortened main rotor shaft (too tall in the kit)
                            [ATTACH]80422.IPB[/ATTACH]
                            [ATTACH]80423.IPB[/ATTACH]
                            [ATTACH]80424.IPB[/ATTACH]
                            [ATTACH]80425.IPB[/ATTACH]
                            Mistakes/forgotten:
                            • Opened the fuselage under the grilles (now you can see side to side through them)
                            • Not opened the fuselage under the APU grilles (at least you can't see through, see above)
                            • glued sponsons before closing the fuselage. to get a good fit I inadvertently deformed the bottom middle of the fuselage forcing me to use a lot of putty to properly close the fuselage (and losing rivets)
                            Next steps:
                            • cockpit and windshield assembly
                            • fuselage final assembly (antennas, pitots, etc.)
                            • final primer
                            Thank you for reading and hope you like it
                            Francesco
                              • 18302
                              Looking great Francesco.
                              As for the vast amounts of putty. I think you might be exaggerating just a bit.
                              Cheers.
                                Thanks Ian
