Dave's Revell 1/48 B24D Liberator
    • 18302
    Looking good Dave.
    For the lightening of the olive drab, you might want to try yellow instead of white. Have a play and see which you think best.
    • Dave W
      • Jan 2011
      • 4713
      #62
      Originally posted by \
      Looking good Dave.
      Come to think of it I used yellow on my 1/24 Spitfire .I liked the result so will do it on this one.
      • PaulTRose
        • Jun 2013
        • 7108
        • Tattooine
        #63
        jeez, thats a big kit, going to be impressive when its finished
        Per Ardua
          • 22954
          #64
          Nice work so far Dave
          • Dave W
            • Jan 2011
            • 4713
            #65
            [ATTACH]108705.IPB[/ATTACH]
            [ATTACH]108706.IPB[/ATTACH]
            [ATTACH]108707.IPB[/ATTACH]
            This evening I've had a go at fading the paint finish.Ive added some yellow to the olive drab and sprayed it in the centre of some panels.Last time I tried this I toned it down with a fine over spray of the base colour.Then after several coats of klear and Matt coat the effect was almost lost.So I'm not going to tone it down this time.This aircraft also had some medium green blotches on the wings and tail.Thats tomorrow's job.
            • flyjoe180
              • Jan 2012
              • 12945
              • Joe
              • Earth
              #66
              Mission accomplished, the fading is looking very convincing in these photos Dave.
              • Dave W
                • Jan 2011
                • 4713
                #67
                [ATTACH]108891.IPB[/ATTACH]
                [ATTACH]108892.IPB[/ATTACH]
                [ATTACH]108893.IPB[/ATTACH]
                This aircraft had medium green blotches sprayed on the leading and trailing edges of wings & tailplanes.My conversion chart gave Humbrol 149 as a match for the FS number.So I sprayed some on free hand.Then I did some fading of the underside neutral grey colour.
                • flyjoe180
                  • Jan 2012
                  • 12945
                  • Joe
                  • Earth
                  #68
                  Nice work Dave, that came out rather nicely. Good to see those conversion paint numbers, it confirms what I had down for my B-17F.
                  • Dave W
                    • Jan 2011
                    • 4713
                    #69
                    [ATTACH]108959.IPB[/ATTACH]
                    [ATTACH]108960.IPB[/ATTACH]
                    [ATTACH]108961.IPB[/ATTACH]
                    [ATTACH]108962.IPB[/ATTACH]
                    [ATTACH]108963.IPB[/ATTACH]
                    I've painted the leading edge de icing boots on the wings.Then I finished painting the undercarriage legs and my scratch built brake lines.I was about to mask the tailplanes and the Inlaws turned up.So I will have to do that tomorrow night.
                    • Dave W
                      • Jan 2011
                      • 4713
                      #70
                      [ATTACH]109798.IPB[/ATTACH]
                      [ATTACH]109799.IPB[/ATTACH]
                      [ATTACH]109800.IPB[/ATTACH]
                      After painting the black de-icing strips on the tail surfaces I gave the whole model a coat of Klear. Then I applied all of the decals. The national markings on the fuselage sides took several applications of Microlsol to get them to settle over the wind deflectors forward of the gun positions.And I had to touch them in with paint where they split.
                        • 22954
                        #71
                        Looking good Dave and a pity about that decal splitting.
                        I think the best bet now is to cut the decal along the edge of the deflectors add some more sol so the decal sits flush to the sides so you don't see the split then paint the gap
                        • Dave W
                          • Jan 2011
                          • 4713
                          #72
                          [ATTACH]110444.IPB[/ATTACH]
                          [ATTACH]110445.IPB[/ATTACH]
                          This ones not far from the finishing line.Ive got quite a bit done since my last post.Whilst glueing the wings on I dropped the model.Only from about 6 inches onto my cutting may.But because of all the weight in the nose it was enough to break the nose transparency off.And it broke into two pieces.So I glued the broken pieces together and superglued them back onto the model.The join goes through the middle of a window pane.But I will just have to live with it. All that's left to do is build the gun turrets,attach the props and do some more weathering.
                          • flyjoe180
                            • Jan 2012
                            • 12945
                            • Joe
                            • Earth
                            #73
                            Our daylight bombing campaign is nearly ready Dave Nice job on the repair.
                            • yak face
                              • Jun 2009
                              • 14237
                              • Tony
                              #74
                              Looking fantastic Dave , great work .You can always say the crack in the nose transparency was caused by a close Ak Ak burst !! cheers tony
                                Looking good Dave, the broken section is hardly noticeable - I had to look hard to see it!
