1/32 Supermarine spitfire MK.1XC Tamiya
    Thats one sweet looking Spit!
      Enjoyed.
      I'm sure this will go to a very happy customer
      • geegad
        • Mar 2010
        • 2329
        #18
        nice spit bud and really love the scarf flapping in the wind top stuff
          Looking great Mike
            Originally posted by \
            Nice one Mike it's funny to see how models differ slightly manufacturer to manufacturer.
            I didn't include the antenna wire when I did mine and I really wanted to but I read that it was integrated into the mast on the mk. IXc, it would be interesting to find out if anyone one has any views on this.
            Lovely build Mike and love the pilot
            Phil
            Yep! I have a view on this- In the Spitfire Mk VIII, there was no radio mast, and the MK VIII was basically a Mk IX with extended range and higher altitude limitations. There was probably no mast on the Spitfire MK IX. As a matter of fact, as I scour my reference books, there is definitely no mast. I did put a mast on my Mk VIII, so I am not guilt free..... However, it is now gone
              BTW, very nice work mike
              • flyjoe180
                • Jan 2012
                • 12950
                • Joe
                • Earth
                #22
                Surely you guys mean aerial antenna wire as opposed to mast?
                • PhilJ
                  • May 2015
                  • 1145
                  #23
                  John says there was no mast, I was under the impression that there was no wire and that the transmitters receivers were integrated into the mast I found this:
                  The new equipment with its shorter wavelengths did not require the aerial wire from the mast to the fin and the mast housed the antenna. The triangular prong was removed from the mast. After some months of delay, from September 1940 front-line Spitfires were re-equipped with the new radios as a matter of priority and by the end of 1940 most aircraft had the mast without the wire and prong, although most retained the redundant anchor point on top of the rudder. It is more than likely that the various Maintenance Units (Mu)s would have have been responsible for fitting the new equipment to factory fresh Spitfires.
                    Sorry, gentlemen, but the VIII had a mast, and the IX had a mast, both with its VHF aerial inside and out of view. The XIV had no mast, since the aerial was replaced by a whip type.
                    • PhilJ
                      • May 2015
                      • 1145
                      #25
                      Yep, that's what I wrote. That's why I didn't put a antenna wire on mine but it was tempting
                        erm, what sort of aerial/mast, as my friend used to fly mk VIIIs, and he clearly told me that there was no wire leading from the aerial mast....
                        Here is a wartime photo of a MK VIII operating from Italy
                        [ATTACH]113384.IPB[/ATTACH]
                        However, here is a VERY confusing profile of a MK VIII showing an aerial. Most likely incorrect
                        [ATTACH]113385.IPB[/ATTACH]
                          Yes. Only the MK Is and MK Vs had the mast running from the tail to the aerial post. only MK Is to Vs operated during this period (1940)
                          Here is a pic of a wartime Mk IX from the polish foreign RAF squadron (no aerial)
                          [ATTACH]113383.IPB[/ATTACH]
                            Can we, please, get something straight? The MAST is the upright "pole" sticking out of the fuselage behind the cockpit; the AERIAL is the stainless steel multi-strand wire, which, in 1940, due to the use of HF radio, (and very occasionally thereafter, usually Russia ) ran between the MAST and the rudder. From early 1941, the AERIAL, due to the radio being VHF, was short enough to be fitted inside the MAST, so it was no longer visible.
                              Good to know. Anyway, I guess you can see what I mean
                              • PhilJ
                                • May 2015
                                • 1145
                                #30
                                Yep that's right, that's what I said from the very beginning. Please let's leave it there lads I'm getting dizzy going round in circles
                                The main point is it is still a great build
