Stona's Bf 109/Ju 88 'Mistel'.
  • stona
    • Jul 2008
    • 9889
    I did a bit of a build thread here:
    So this is a 'Mistel 1', 'White 2' of 2./KG 101 as seen at St Dizier, France in June 1944. A Mistel was a combination aircraft, in this case a Bf 109 F-4 and a Ju 88 A-4 from which the cockpit was removed and replaced with a warhead. This was the SHL (Schwere Holladung) 3500. It contained 1,700 Kg of explosive in a hollow charge. The electrical crush fuses for the explosive are at the end of a 2.75 m probe, a hollow chamber lined with soft metal (aluminium and copper were used), giving the device its nick name 'Elephantenrussel' or elephant's trunk. For those not familiar with hollow or shaped charges, when the explosive (70% Hexogen/30% Trinitrotoluol) at the back of the warhead was detonated it would focus its force on the soft metal liner which would liquefy and project forward at 20 times the speed of sound. Test showed that this jet could penetrate 8m of armoured steel or 20m of concrete.
    History lesson over, here's some pictures of the completed model.
    The kits are from the Italeri Mistel boxing. They were both fairly stress free. Paints are a mixture of Colourcoat and Humbrol enamels. Final varnish a mixture of Klear and Vallejo matt to give a satin(ish) finish.
    Edit: I've just noticed that the Bf 109 has shed its tail wheel! If I ever find it I'll stick it back on
    • 18286
    WOW!
    Great job Steve. A very impressive model with a very impressive paint job.
      Very good painting, good quality! Well done. I am impressed!
        Stunning.
          Excellant work.
          • yak face
            • Jun 2009
            • 14072
            • Tony
            Superb work steve , when you see  the mistels like this you realise how hard it must have been for the bf109 pilot to control the two aircraft . Once separated was the ju 88 just a free fall glide bomb or did the pilot still have some directional control over it?
              • 22851
              Great work there Steve
              • Gern
                • 9273
                Beautiful.
                  Nice work mate. Very impressive.
                    Great job Steve love the paint job mate. The backdrop makes for a great display
                    • stona
                      • Jul 2008
                      • 9889
                      The easy bit was flying the combination! Take off was a little tricky. All the pilots seem to agree that it was no more difficult than flying a single aircraft. There were no mechanical links between the control surfaces of the two aircraft.  'Open loop' control principles, governed by the Mistel's speed were employed. The control rods of the upper, controlling, aircraft were linked to potentiometers which regulated the power supply to electrically driven servo-actuators fitted to the carrier aircraft's flaps, ailerons, elevators and rudder. It was, for the time, a very advanced predecessor of the 'fly by wire' systems which are almost standard today.
                      The lower component, once released, flew to the target on an auto pilot. Aiming and acquiring the target was dependent on the Mistel's gyro stabilised gun sight which could calculate the lead required for the Mistel's lower component, allowing it to fly under auto pilot and in a straight line to the target, even if it was moving.
                      Fritz Haber wrote, about a moving target like a ship.
                      "Target acquisition is initially achieved by locking the gyro's axis, and thus the line of sight, and aiming the aircraft at the target. The pilot then frees the gyro and afterwards has nothing more to do than align and maintain the target in the reticle. He has then achieved the situation with the correct lead angle depicted in the sketch [which I can't reproduce] It is clear that in this situation, where the target is being continually tracked, the upper aircraft can be separated at any time, because the overall situation will not alter....The simplicity and certainty of hitting a target using the Mistel method was based on the premise that the carrier aircraft [the bomb] continued to fly in a straight line and did not have to rely on the calculations needed for ballistic flight."
                      For a stationary target, like a bridge or factory, the same method was used, but no lead was calculated. The important point is that the carrier aircraft's auto pilot simply had to keep it on a predetermined straight course, something it was quite capable of doing. There was no requirement for any maneuvering. Unfortunately the system was less than reliable. IF the Mistel's managed to get within range to separate then the lower components did sometimes get close to the target, but they also had a tendency to dive into the ground (or sea).
                      • eddiesolo
                        • Jul 2013
                        • 11193
                        Wonderful work Steve, as with all your models the quality and finish are top notch and the history you provide makes them come alive.
                          Another great build Steve and a good bit of knowledge and understanding of how these things worked top job all round
                            Great job, Steve. And I always enjoy your 'history lessons'!
                            • Snowman
                              • Oct 2014
                              • 2111
                              It's a huge flying shaped charge!! O.o
                              That is cool! B|
