This is a quick build - you get good results in a short time. I haven't blogged this - there are only 48 parts, of which 8 are rockets. I added a pilot, but you can't see much through the heavily framed cockpit. Fit is superb - dry fitting is not needed, if you do, you may not get the parts apart again.
There are two finishes - both natural metal with an olive drab top stripe. I chickened out on the second option, I just didn't fancy putting all those segments onto the drop/tip tanks - these are the remaining decals
One observation - the decal placement drawings are tiny - Had to use my magnifying glass.
These Easy Assembly models give you a good result in a short time. I'd say they were absolutely ideal for a beginner, but more experienced modellers will be surprised at the level of detail. You can pick them up from under £7 - I've now a few in the stash -as mojo restorers, or a palette cleanser!
