Hi Guys, here is my completed example of the recently tooled 1/48 Airfix P51D Mustang. In keeping with my loose theme of building 'local' aircraft - when I do allied ones anyway - (not hard when you've lived all your life in Eastern England), this has been built out of the box as an aircraft flown from Martlesham Heath just outside Ipswich in 1945. It's a place I know well.
Completed over the past few months, this is my first attempt at a metallic finish and it's something I need to work on next time I give it a go. There seems to be a fine line between not enough and too many when it comes to number of coats. I also had a problem with the preceding gloss black coat on the underside at first, the rectification of which was only partially successful. I am happier with the transparencies on this build though and used Deluxe Materials 'Looks Like Glass' which certainly has helped. Paint was Vallejo metal colour white aluminium and I sprayed the black stripes rather than use the kit decals - the decals took ages as it was....
Anyway, here are the pics...
[ATTACH]444315[/ATTACH]
[ATTACH]444316[/ATTACH]
[ATTACH]444317[/ATTACH]
[ATTACH]444318[/ATTACH]
[ATTACH]444320[/ATTACH]
[ATTACH]444319[/ATTACH]
[ATTACH]444314[/ATTACH]
As always, thanks for looking in - tips and comments welcome....
Nick
Nick
