Frog 1/72 DAP Beaufighter mk21
  • flyjoe180
    • Jan 2012
    • 12463
    • Joe
    • Earth
    #16
    Fantastic photo Tony :thanx: Dave has a point, a Beaufort would look right at home in that group.
    • yak face
      • Jun 2009
      • 13870
      • Tony
      #17
      Thanks for the stars Ian! The rear gunners dome isnt too bad as far as thickness goes , i think it just catches the light badly cause its right up on top, the pic taken from straight overhead shows it a bit better. I did think about crashing a replacement but it was supposed to be a " quick" build so didnt bother!! cheers tony
        I see you have a lot of work on this baby... but you done it all around in fantastic way
        Great build
        Roman
        • spanner570
          • 15482
          #19
          Cracking build Tony, great result.
          After a Spitfire, I think this was the next aircraft I built, way, way back - and great to see one again!
          Big 5!
          Ron
          • Vaughan
            • Apr 2011
            • 3175
            #20
            A great build Tony with some nice pre-shading. The scratch building and alterations have come out well. Could you explain the crash moulding.
            • yak face
              • Jun 2009
              • 13870
              • Tony
              #21
              Thanks guys , Vaughan the crash moulding for a small part like this couldnt be simpler. I just got a piece of clear acetate (from a chocolate box if i recall , but loads of types of packaging have clear bits on them) , I then got the kit part , stuck it on a wooden stirring stick , then heated the acetate over a candle and when soft enough , pushed the kit part into it . I had several attempts and chose the best one , cutting it out with fine scissors . The beauty of this is that the clear acetate used in packaging is plentiful so it doesnt cost anything to experiment . cheers tony
