I'm calling this done, though between me and you I noticed when I took the photos that I haven't fitted the wing tip navigation lights
My subject was Bruno Hegenauer's Fw 190 A-2 as seen in France in the spring of 1942.
The aircraft is at cockpit readiness (sitzbereitschaft) with a pilot, possibly Hegenauer aboard. Sitzbereitschaft was the most immediate state of readiness, the aircraft would take off as soon as an alarm was given.
The Geschwader Stab of JG 26 'Schlageter' adopted a unique marking system whereby the pilots' initials were applied to the sides of the aircraft in black lettering.
This A-2, W.Nr. 0202 was an early example and I have chosen to use the RLM 71/02/65 camouflage scheme. It could just as easily have been in 74/75/76 but I've got a lot of that scheme on my shelves already. A good, if not exactly rigorous reason for a change!
Here's the model. You can see the build here.
Finally an imitation of a picture taken of Armin Faber's aircraft, presumably by someone on a ladder or upper floor!
Bruno Hegenauer was killed in Tunisia in May 1943. At the time he had five victories. This relatively low number was probably a result of his having flown as a wingman to several 'experten', including Galland, throughout his career. In the Luftwaffe system a famous ace's wingman was not expected to make attacks himself.
The aircraft didn't last that long either. Oblt. Wilfried Sieling was shot down by a Spitfire whilst flying it on 30th April 1942. The aircraft dived vertically into the ground near Gravelines (France), killing Sieling and being 100% destroyed.
