Dave Ward's B-P Defiant - Airfix 1/48 for Colin's Battle Of Britain GB finished!
    I'm calling this finished:
ID:	1130186Click image for larger version
ID:	1130185Click image for larger version
ID:	1130194Click image for larger version
ID:	1130187Click image for larger version
ID:	1130188Click image for larger version
ID:	1130192Click image for larger version
ID:	1130193Click image for larger version
ID:	1130190Click image for larger version
ID:	1130191Click image for larger version
    The Airfix 1/48 Defiant is a good model, the assembly, especially of the turret is pretty tricky & needs a little easing here & there to fit. The open turret doors are a very tight fit & need no glue!. Some of the detail will never see the light of day again. If you build this with cockpit & turret closed, then the PE is really superfluous.
    I can't remember a model where I have dropped so many bits, lost bits ( still haven't located my missing masks ) I seemed to have spent ages creeping round, looking for absconded parts - what is fitted now is the third control column, the first two vapourised...................
    Thanks to Colin for overseeing this GB & thanks all for dropping by
    • 19106
    I know it was a failure, but I’ve always had a soft spot for this aircraft. This is a great rendition Dave, well done. Makes me want to buy one, even though I’m not building kits at the moment LOL....
    • KarlW
      • Jul 2020
      • 1522
      Got to be happy with that Dave.
      • rtfoe
        • 9208
        • Richard
        • Shah Alam, Malaysia
        Nicely built and painted Dave, I've only made one with the old Airfix 1/72 kit and have the later 1/48 like yours in the stash so with how its gone together so nicely I'm going to attempt that soon.
        • spanner570
          • 15599
          Excellent build, Dave. and nicely presented too.
          • outrunner
            • Apr 2019
            • 2420
            Looks good Dave.
            Andy.
            • Gern
              • 9302
              I like it.
              • Neil Merryweather
                • Dec 2018
                • 5306
                • London
                very nice indeed ,Dave
                • NickT
                  • Apr 2019
                  • 194
                  Excellent Dave - Looks good !
                  • Richard48
                    • 2176
                    • Richard
                    • Clacton on Sea
                    Ive always liked the rakish look of the Defiant.Done a nice job Dave.
                    Rich.
                    • yak face
                      • Jun 2009
                      • 14237
                      • Tony
                      , Nice job dave , cheers tony
                      • Defiant911
                        • Feb 2020
                        • 640
                        [ATTACH]394247[/ATTACH][ATTACH]394256[/ATTACH]
                        [ATTACH]394246[/ATTACH][ATTACH]394255[/ATTACH][ATTACH]394248[/ATTACH][ATTACH]394249[/ATTACH][ATTACH]394253[/ATTACH][ATTACH]394254[/ATTACH][ATTACH]394251[/ATTACH][ATTACH]394252[/ATTACH][ATTACH]394250[/ATTACH]
                        Looks excellent Dave and the weathering is a great finish. I always get nervous about weathering as you spend all that time painting so carefully and then Splash all this weathering on which in the wrong hands can go very wrong( I know from bitter experience) but clearly you have pulled it off.
                        Nice work.
                        • Fernando N
                          • 2448
                          Very nice result Dave, top man for persevering despite all the troubles and bits disappearing:thumb2::thumb2:
                          • Lee Drennen
                            • 7738
                            Dave. Very nice finish nice touch on the weathering
                              About weathering:
                              It's one of those things that doesn't scale too well - to make it visible on a 1/48 model, you have to enlarge the effect. When you look at a blown up picture, it looks as if someone has been at it with a rasp & a bucket of Nitromors!
                              To take an improbable example. Someone climbs on a wing with hobnail boots & scuffs his feet. He leaves several scratches 200mm long X 5mm wide. Scale that down to 1/48, and you get 4.2mm X 0.1mm, so narrow as to be invisible & unpaintable, that you have to increase the size to make it visible - say 0.5mm - which gives an actual scratch size of 24mm!
                              The same goes for chipping - you must consider what the actual size of paint removal is. Some models with extensive chipping show areas that would be several metres long X 1/2 metre wide! You have to get a balance between what is visible on the model & what actually happens on a full size beast. Blown up photos will always look OTT ( of course the smaller the scale the worse it gets )!
