Hasegawa FW190 ... 1/32 (kit # 08056)
  • saguy
    • Feb 2011
    • 570
    Hi there ... i purchased this model today and on opening the box at home found that there are no plans in the box [ATTACH]96692.IPB[/ATTACH]
    .... a couple of questions:
    are there any web sites that have plans that can be downloaded?
    does anyone know what version this FW190 is?
    thks a ton
    Lindsey
    Looking at the two gun barrels and the pilot's seat seems to be an A-8....
    Anyway, I'm sure Steve (Stona) will come to your rescue soon
    • saguy
      • Feb 2011
      • 570
      Tx Polux ..... very helpful ... i am a wee bit wiser now ....
        If the stabilizer number is 410004 and under the cockpit number 23, may be the Focke Wulf FW190A-5 Walter Nowotny. The Hasegawa has the same model in Limited Edition #8224.
        Regards
        ajcmac
        • stona
          • Jul 2008
          • 9889
          I think Antonio is right. The markings certainly look like Novotny's A-5.
          It's the old and rather basic tooling from a while ago. You can make a decent Fw 190 out of it, but its not anywhere near as nice as the newer ones.
          There's a very good chance I have an instruction sheet for this kit, though maybe not this version, I'll let you know later.
          Edit: Sorry...don't seem to have them anymore
          • saguy
            • Feb 2011
            • 570
            Originally posted by \
            If the stabilizer number is 410004 and under the cockpit number 23, may be the Focke Wulf FW190A-5 Walter Nowotny. The Hasegawa has the same model in Limited Edition #8224.Regards
            ajcmac
            thks a lot ...checked the decal sheet and there is the stabilizer # 410004 ... oddly though whilst the 23 appears on the box art there is no decal for it .... regards lindsey
            • saguy
              • Feb 2011
              • 570
              I think Antonio is right. The markings certainly look like Novotny's A-5.It's the old and rather basic tooling from a while ago. You can make a decent Fw 190 out of it, but its not anywhere near as nice as the newer ones.
              thks steve ... very informative as per usual ... appreciate you looking for the instructions .. you are right in that it is a rather basic kit so with a bit of luck i should be able to muddle my through it with a bit of common sense and google as my friend ...
              cheers
                Usually when I have difficulties with the instruction sheets visit two pages.
                www.1999.co.jp
                www.model-making.eu
                Unfortunately, none of them has the instructions of this model.
                Regards
                ajcmac
                • stona
                  • Jul 2008
                  • 9889
                  According to G R Morrisson, who I would believe, Novotny had the outer wing weapons removed from this aircraft.
                  I'm also confused by the werknummer 410004 which is not a Focke-Wulf number. It might be 470004, which makes the aircraft one of the first Arado built A-6s
                  • saguy
                    • Feb 2011
                    • 570
                    tx Steve .... i found this when i searched on the werknummer 410004
                    Fw 190A-6 of I./JG 54 (Werk Nr 410004) of Walter Nowotny.
                    Major Walter "Nowi" Nowotny (7 December 1920 – 8 November 1944) was an Austrian-born German fighter ace of World War II. He is credited with 258 aerial victories in 442 combat missions. Nowotny achieved 255 of these victories on the Eastern Front and three while flying one of the first jet fighters, the Messerschmitt Me 262, in the Defense of the Reich.
                    And this when i searched 470004 ....
                    from your findings it looks like the decals sheet is incorrect and should be 470004
                    rgds
                      • 18271
                      There is a fair chance that Al (Flounder Al) has the destructions for one, He has a serious case of FW-itis lol
