clear varnish
  • meggsy
    • Jun 2011
    • 421
    clear varnish
    ive just about finished a tamiya me109 i put a few of the small decals on but whilst reading though the forums on here i see a lot of you coat your models ive decided to do the same im going use humbrol matt cote is this ok and will it effect the decals already applied cheers
  • yak face
    • Jun 2009
    • 14237
    • Tony
    Hi steve, the clear varnish wont affect the decals , just be careful not to get any on the canopy or it will make it a bit cloudy , cheers tony
    • meggsy
      • Jun 2011
      • 421
      can i brush it on or has it got to be airbrushed if i can brush it will it leave brush marks cheers
      • yak face
        • Jun 2009
        • 14237
        • Tony
        It can be used either way steve, although as you say if its brushed you will get some brush marks. You could thin it slightly with white spirit if youre going to brush it but be careful not to get too much on and get runs. If you airbrush it then obviously youll need to thin it also, cheers tony
        • meggsy
          • Jun 2011
          • 421
          nice one cheers mate
          • Dave W
            • Jan 2011
            • 4713
            Humbrol matt cote is not a varnish that i would recommend.It tends to dry in white patches.Im told that if it is thoroughly mixed this wont happen.However, ive stired the stuff untill my arm was about to drop off and i still had a problem with it.Wouldnt touch the stuff with a barge pole now.I use Vallejo matt clear which is the best matt varnish ive ever tried.Wouldnt use anything else after using this stuff.Its acrylic and works equally well as a final coat over enamel or acrylic paint jobs.
            • meggsy
              • Jun 2011
              • 421
              cheers for that dave can the vallejo be brushed on
                Go with Dave W. Just used Vallejo Matt varnished (air brushed) on a 1/72 Lancaster. Really needed only 1 coat but gave two.A really nice finish. Used Humbrol on my first ever model not again.
                Matter of interest just been watching a programe on paintings & they showed a painting with an oil varnish then on computer with the varnish removed. Remarkable how the oil based varnish (Same as Humbrol) turned brown & all the blues which read as green.
                • Dave W
                  • Jan 2011
                  • 4713
                  Ive not tried brushing it on,but dont see why it shouldnt work ok.Ive airbrushed it on four models so far and got a perfect finish everytime.
                  • Dave W
                    • Jan 2011
                    • 4713
                    Revell do an enamel matt clear which ive used in the past.It works well and is far superior to the awful Humbrol stuff .I havent been able to get any for a while.
