Joint venture
  • jameshoughton1997!!!!
    • Oct 2015
    • 136
    Joint venture
    So i was tidying the model area the other day and the other half walked in and said i like the look of that model we should do it together so i thought i gota jump at this so i need some advice goner go all out its the airfix curtis tomahawk in libiya 1941 colours i wana do i diorama with it make a real project out of it so any suggestion on the dio or were to get the things for the dio i got the board goner be starting when i have everything together
    • 18302
    As for the where to buy... Scale model shop would be a good place to start
    as for the diorama I guess there will be sand. lol
      Well you're probably talking about an airfield setting, so I'd recommend using bird grit for sand. It's good for smaller scales like 1/72.
      Alternatively, you could use a sheet of wet & dry sandpaper as a runway.
      If you were feeling adventurous, perhaps add a German Panzer III & pose the Tomahawk in flight doing a fly-by.
      Whichever way you decide to go, I'd definitely recommend adding some punctuation to your posts James - it would make them much easier to read
      • colin m
        • 9024
        • Colin
        • Stafford, UK
        Or I might suggest not over doing it as, I assume, it's your partners first build. Maybe just do the model this time around.
