I am building the Trumpeter 1/48 kit of this under rated aircraft.
Two questions perhaps someone could answer.
1/. Is the internal geodesic framework meta or wood? I suspect metal. The answer will determine whether I dry brush with metal powder or brown pigment.
2/ the side window guns. Would it be right not to leave them poking out of the side windows for a parked up aircraft? These will be incredibly vulnerable just cemented into place so I am trying to decide whether to leave them off or stacked inside. If I need to have them poking through the side windows I will have to cut the barrels off to add as a final fitting.
In the meantime. I have tried my first wood panels. A spray of Ochre Wood then a Earth MiG Oli Brusher to give it a wood grain. I think they look OK and as so little will be seen will work well. What do you think on this.
I will post a completed build thread when done.
