Hello all
I've recently had a couple of problems using Humbrol 150 ml varnishes from the spray can, both with the matt and the gloss
While spraying the final overcoat of matt on a 1/48 Hurricane Mk.1 pre-1939, the coat sort of clouded up a bit in some areas. This whitening effect disappears when you wet it but soon returns when it dries. I did another coat which got rid of it in some areas but came up in others. I did not want to continue with multiple coats forever...
It doeasn't look too bad, but still would be nice to fix it....anyone any ideas as to what might be causing it?
Also, witht the gloss, it caused the paint in a few areas to bubble up, requiring sanding, re- painting and re-sprayng, not to mention swearing. Anyone any ideas? or maybe I'm just a crap modeller
On the bright side, the satin stuff works perfect!
Cheers to all, Saul
Cheers to all, Saul
