Rigging a 1/72 F1 Sopwith Camel
    Hello
    I'm working on this model, my first ever 1/72 and it's tiny! The length of the fuselage is about three inches and the wing span less than five. How on earth do I rig it please? Nothing has been supplied although the instructions show some sort of thread. There are no points to anchor the rigging. What do I use, how do I attach the rigging? OMG!!!!!!!!!!!!!!!!!!!
    Thanks
    Aidan
    :surrender2:
    The one and only time I've done it I drilled right through the wings and used fishing line held in place with superglue
    The Aircraft specialists might have better suggestions
      I cheated, i brought one ready made... quite clever i thought lol
      [ATTACH]43774.vB[/ATTACH][ATTACH]43775.vB[/ATTACH][ATTACH]43776.vB[/ATTACH][ATTACH]43777.vB[/ATTACH][ATTACH]43778.vB[/ATTACH][ATTACH]43779.vB[/ATTACH][ATTACH]43780.vB[/ATTACH][ATTACH]43781.vB[/ATTACH]
      Might help you a little.
      Andy
      [ATTACH]47005.IPB[/ATTACH]
      [ATTACH]47006.IPB[/ATTACH]
      [ATTACH]47007.IPB[/ATTACH]
      [ATTACH]47008.IPB[/ATTACH]
      [ATTACH]47009.IPB[/ATTACH]
      [ATTACH]47010.IPB[/ATTACH]
      [ATTACH]47011.IPB[/ATTACH]
      [ATTACH]47012.IPB[/ATTACH]
        i made plugs from the sprues then sanded them down and painted seamless then,though mine was bigger at 1/28
        mobear
          • 22826
          Hi Aidan When i did my 1/72 Swordfish, i used thin fishing line for the rigging, before putting the wing struts on i made a small groove at the top and bottom of them so you could put the line under and over the struts. Then when the glue was dry i used a LITTLE heat from a lighter to stretch the fishing line ( if you use this method i would practice on some spare sprue just to see how the line reacts to the heat ) Hope this helps, If you wish to have a look at mine its under 1/72 Airfix Swordfish
            Thanks Ian
            Am having trouble finding the pic. Is it in your own gallery?
            Aidan
              • 22826
              [ATTACH]43832.vB[/ATTACH] [ATTACH]43833.vB[/ATTACH] [ATTACH]43834.vB[/ATTACH] [ATTACH]43835.vB[/ATTACH] I hope these help Aidan
              [ATTACH]47057.IPB[/ATTACH]
              [ATTACH]47058.IPB[/ATTACH]
              [ATTACH]47059.IPB[/ATTACH]
              [ATTACH]47060.IPB[/ATTACH]
                Yes they are very helpful.Manuy thanks Ian.
                Aidan
