Help with overlaying Waterslide Decals
    I have a superscale decal sheet that requires me to place one decal on top of the other to achieve the image on the model I desire. Each of the two decals has a different color. When one is layered on top of the other it represents this image correctly. I am questioning the proper techniques to pull this application off correctly.
    My thought process is as follows:
    1. airbrush a coat of future acrylic, let dry
    2. apply a coat of Microset
    3. apply the 1st waterslide decal, remove excess moisture let dry for 10 min.
    4. apply a coat of Microsol, let dry overnight
    5. apply a coat of Microset over the 1st decal (previously applied)
    6. apply the 2nd waterslide decal and position it accordingly, remove excess moisture let dry for 10 min.
    7. apply a final coat of Microset over the 2nd decal previously applied, let dry overnight
    8. airbrush a coat of Testor's dullcoat over the decals to seal them in place.
    I have never tried this before. Will my thought process work without creating a mess? Can anyone out there help me?
    Thanks in advance,
    Tom
  • stona
    • Jul 2008
    • 9889
    I've done almost exactly that when applying the red dot in the centre of a roundel,or the little first aid crosses on Balkenkreuz. I didn't apply any microsol before both decals were on, but if you let everything dry, as in your proposed plan, I don't see why that should be a problem.
      Thanks Steve!
      Merry Christmas!!!
