Airfix and Revell Lancasters
    Hi guys and girls
    Could someone please advise is it possible to put the wings of the Revell Lancaster (Dambuster) onto the Airfix kit as i wish to show the engines both kits are 1 /72 scale and will be shown with the Airfix Bomber re-supply set .
    Many thanks
    Kevin
    P.S sorry if this has already been posted
  • yak face
    • Jun 2009
    • 14308
    • Tony
    Hi kevin welcome to the forum. I imagine its entirely possible to do the mix up of kits , you might just have to do a bit of surgery on the method of fixing . They both have a spar type of fixing system , the airfix one having the wheel wells in it , if the wells are in with the revell wing then all you would need to do is adapt the airfix spars to fit into the revell wing , just do it carefully a bit at a time ,remember - you can always cut a little more off but its much harder putting it back on!! If you did us a "under construction" thread it would be very useful for anyone else thinking about the same thing , cheers tony
      thanks tony will do so when i start the kit
