Hi all don't know what happened there I am feeling so s@@@ still working even though I feel bad. Got the body stick to the chassis eventually but now the rear window has popped out. After the trouble of getting the body stuck I am definitely not un gluing it, anyone got any ideas how to fix it the mood I'm in at the moment it could quite easily end up on the fire.
Airfix 1/32 WRC Fiesta
Guest -
Looking good Ken.
Have you any sticky buds. Stick with a very sticky bit on the end. If not can you use blue or white tack fixed firm to a bit of sprue. Push the window inside glue around the edges and then pull the window in with the sprue/blue tack.
Carried this out a couple of times on aircraft windows where they have popped and it works well but you need patience and to work slowly..
LaurieComment
