1/12 1966 Ford GT 40
  • Stefee
    • Feb 2023
    • 1000
    • Stefan
    • Hemel Hempstead
    Next to appear whilst paints,glues etc. dry on other builds.
    This kits manufacturer is not named but a direct copy of the Trumpeter/Magnifier offering with extra decals to do Ken Miles car.
    Loads of very well packaged sprues and pipes, hoses, springs, screws, PE etc. The mouldings are crisp and detailed with very minor seams and no flash however there is a ton of (very well done) chrome which just doesn't belong and needs stripping. I have bought AM switches, rivets, bolts, screws, braided hoses, decals and a spare wheel/tyre. The box contained the bodywork and some clear parts which are the worst part of the kit. I built the seats previously as in another thread.
    ​ 32 page clearly illustrated assembly book with some dodgy paint call outs. Strangely some parts are pre painted in questionable colours and there is no distributor, ignition leads, starter motor snd the top of the timing chain cover is missing - will attempt scratch building components. The Ivory coloured parts have been stripped of chrome and the missing parts locations highlighted.
    ​ This is going to take quite a while so please bear with me for sporadic updates.
  • Stefee
    • Feb 2023
    • 1000
    • Stefan
    • Hemel Hempstead
    Finally finished scratch building the distributor and HT leads and hopefully in the correct firing order. Covered the top of of the timing cover and starter motor + coil WIP.
    Studying the kit engine and photos of the 1:1 there is a glaring ommission- no water pump supplied so will try to make a facsimile but maybe a step too far for my skill level.
ID:	1267617 Click image for larger version
ID:	1267618 Click image for larger version
    • minitnkr
      minitnkr commented
      Editing a comment
      Electric WP might be easier to scratch.
  • Stefee
    • Feb 2023
    • 1000
    • Stefan
    • Hemel Hempstead
    Starter motor, coil and water pump scratched and hollow backed alternator filled and detailed a little.
    Contemplating wether to make the auxiliary drive belt more realistic but will mostly be hidden when fitted.
ID:	1267803 Click image for larger version
ID:	1267801 Click image for larger version
    • flyjoe180
      • Jan 2012
      • 12931
      • Joe
      • Earth
      Great attention to detail Stefan
      • Stefee
        • Feb 2023
        • 1000
        • Stefan
        • Hemel Hempstead
        Decided to leave the overscale drive belt well alone for fear of really damaging something so decided to bling up the pulleys a bit to divert attention.
        Fabricated the coolant pipes from and to the water pump which will disappear into the tunnel of the cockpit and reappear at the front and onto the radiator. Once finessed and painted will add flexible hoses and clamps in the appropriate locations.
        Blocked up some spurious coolant holes and prepped for oil lines and made a oil supply/return unit for the oil cooler.
        Thanks for following along.
ID:	1267910 Click image for larger version
ID:	1267911 Click image for larger version
          • 16157
          Certainly going the extra mile with this Stefan. Very neat scratching.
          • Stefee
            • Feb 2023
            • 1000
            • Stefan
            • Hemel Hempstead
            Thanks for the kind comment.
            Doing extra on this as it's a large scale so more can be seen and it's my all time favourite Le Mans car - told the missus it goes in the coffin with me finished or not !
            • scottie3158
              • 14564
              • Holbeach
              Some great additional details.
              • Stefee
                • Feb 2023
                • 1000
                • Stefan
                • Hemel Hempstead
                Dry fitted the bundle of snakes exhaust system after adding weld lines to the headers and collectors.
ID:	1268126 Click image for larger version
ID:	1268127 Click image for larger version
                  • 22947
                  A great start Stefan, adding some cracking details.
                  • Stefee
                    • Feb 2023
                    • 1000
                    • Stefan
                    • Hemel Hempstead
                    Further advances on the engine. Hollowed out the core (welch) plugs, added some bolt heads and painted numerous colours. Very light weathering and dry brushing.
                    Dry fitted the exhaust headers and collectors - very happy with the welds but still not sure if too colourful, have to mull it over.
ID:	1268416 Click image for larger version
ID:	1268414 Click image for larger version
ID:	1268415 Click image for larger version
ID:	1268417 Click image for larger version
ID:	1268418 Click image for larger version
                      papa 695
                      commented
                      Editing a comment
                      Those exhausts look fantastic.
                    • HAWKERHUNTER
                      HAWKERHUNTER commented
                      Editing a comment
                      Lovely finish on the exhausts.
                  • scottie3158
                    • 14564
                    • Holbeach
                    Excellent work.
                      • 16157
                      That's a stunning looking engine.
                      • Stefee
                        • Feb 2023
                        • 1000
                        • Stefan
                        • Hemel Hempstead
                        Did some more detailing today. The narrow braided hose was in the kit but frays terribly so sprayed it with hairspray and painted it aluminium with a Galherri marker. The thicker braided hose is Tamiya.
                        The destructions would have you connect the transmission cooling hoses to the engine inlet manifold! so am rerouting to oil cooler when fitted.
                        Decided that I liked the exhaust colours so after an hours manipulation managed to cement them in place.
                        Thanks for looking and the great comments and likes. Click image for larger version
ID:	1268446 Click image for larger version
ID:	1268447 Click image for larger version
ID:	1268448 Click image for larger version
                        • Stefee
                          • Feb 2023
                          • 1000
                          • Stefan
                          • Hemel Hempstead
                          Been busy stripping unnecessary chrome and deleting visible ejector pin marks. Added weight saving holes to internal engine bay panels.
                          Spent 8 hours making the doors fit properly which has worked really well - may have to shave a bit more off to allow for primer, paint and clearcoat.
