Luckily they didn't have MOT's then.
Heller's 1/8 Citroen Traction Avant
Guest -
Hi all I was checking some of the pictures, one advantage of that is looking at pictures of things 2 and sometimes 3 times bigger than the actual thing you see faults you wouldnt see on the actual item, like for instance a lot of the flat areas of rust are, just that flat, no blistering and no reason to be rust coloured, so I,ve fixed that and dulled the doors and bodywork down and started blending panels and adding general grime (I must say I'm quite pleased with the results so far) if things carry on like this I think the finished thing will look quite realistic (of course having said that I will no probably go and ruin it)
does anyone know how to dull down and dirty the windows and windscreen? all tip welcome.Comment
I know Wire wool will take the shine of for sure, but I would not have the bottle to use it on this glorious build
Try some sandpaper or a coarse micromesh. Love the rusting techniques good use of colours. I had a play with rusting on a spare door from the 300sl. I used glue to 'bubble' the plastic it was quite effective.
Thanks Peter and marc, marc I saw that it's a great idea and I will be using it with the salt technique on another build,Comment
Hi all well I'm sure you must be getting bored of this by now (I know you're all so polite you wont say so) so I'll take advantage of your good nature and continue the onslaught.
hi all here is tonights update, I realise the windscreen needs work but its my first effort at doing glass.
does the bird poo look effective.
Guest -
I`m not too sure on the bird crap thing Ken ...... But the rest of it looks really very very good mate. First class work.Comment
Guest -
does anyone know where I can get some decent pics of the dash in these as I want to weather it and cant find any decent pics, here is what I have at the moment
Hi all well its that time of year again, as little aside from the model got the decs up today
I decided the technique I used on the dent in the tank of the Honda I would use it here aswell
seems like sacralige, the chrome on the radiator grill is so exquisite.
but would be out of place on this car,
and the rust devils been about again
